Android Scanner Application
Old Apr 10, 2012 | 06:49 PM
  #46
CGMKCM's Avatar
CGMKCM
Originally Posted by sledhead999
If AE can read from the OBDII port, I don't see why this couldn't do the same. Seems like the limitations are the Bluetooth and processor speed. I wouldn't even care if it had to be corded with a USB connection for my tablet/phone.
I am also curious what adapter radmacks is using.
AE Ford bundle is programmed to be compatible with the J1850-PWM protocol that Ford uses to communicate via the OBD II port on the 7.3 Powerstroke. The 7.3 is the only diesel to use this standard.
The Bluetooth adapters may not be set up for this protocol. I talked with the two different MFGs I used and both stated that they were compatible with the OBDII standard used after 2004 on Powerstrokes.
The MFG write up on Amazon stated both were fully compatible with the J1850-PWM standard ("unlike some of the cheap Chinese adapters" ) . I called both MFGs and they backed away from there write ups.
Buyer beware, If you buy the Blue tooth adapters from Amazon, do your homework and check the feedback from users and also the adapters web page for known compatibility issues.
Old Apr 10, 2012 | 07:08 PM
  #47
sledhead999's Avatar
sledhead999
Thanks. Didn't know that!
Old Apr 11, 2012 | 10:38 AM
  #48
DCClark's Avatar
DCClark
I guess the next question would be, does the Bluetooth Kiwi(88$) or the 250$ module actually have the ability to read the J1850-PWM protocol? If so does anyone have one of these bluetooth modules? Will the Torque app then read more data from the computer of the vehicle? What is the actual limiting point, Bluetooth adapter, Torque app, or not enough sensors on our truck to make it worth while? It would be interesting to see screen shots of the expensive module vs the ones I posted...
Old Apr 11, 2012 | 12:32 PM
  #49
CGMKCM's Avatar
CGMKCM
I bought the Kiwi based on the recommendations on the Torque web site. It did not work on my truck. I called the MFG and that is who told me about the J1850-PWM being UN-supported. On there web site in the forum you can read comments from other Ford owners asking about supportability.
As to your question about usefulness and sensors. I have a scan guage II that scans more pids then the tourque app will. It will not do all of the performance stuff that torque will do like 1/4 mile time and speed, 0-60 speed and time etc.
I also have an Edge cvs that does the same stuff that torque will do but it doesn't read as many Pids as the scan Guage II. I am disappointed that the Edge reads so little of the information. I thought it would be more like AE lite.
The nice thing about torque is the cost and the ability to carry limited diagnostic capability, along with several other nice features with you anywhere you go and in any car you drive. It is not a replacement for AE but not everyone wants or needs AE.
Hopefully the folks that have it working well will post the name of the OBD II bluetooth adapters that they are using.
Old Apr 13, 2012 | 07:30 PM
  #50
radmacks's Avatar
radmacks
Cheap 25$ ebay one. It gets the occasional read errors but as long as you keep it under 10 sensors at one time it works good for the price.
Originally Posted by bigb56
Which BT adapter are you using?
Old Nov 8, 2012 | 01:21 PM
  #51
TREX2000's Avatar
TREX2000
Please tell me which BT OBD interface you are using. I am hearing a lot of comments that say they will not work on the 7.3.
Thanks,
Old Nov 8, 2012 | 01:25 PM
  #52
radmacks's Avatar
radmacks
All the cheap eBay ones are the same
Old Nov 8, 2012 | 03:24 PM
  #53
empiretc's Avatar
empiretc
not really. vGate is one that does work with later year 7.3 trucks. if you have an older one, limit your expectations. it's not really great for our trucks.
In our quest from this thread:
https://www.ford-trucks.com/forums/1...de-reader.html
several different things were tried. the cheapo BT unit works great on a lot of vehicles, but for the 7.3l we found the best code reader options are:
1.) AE
2.) SuperChips 1705 (get a VIN locked one for cheap)
3.) Actron CP9580
The Actron was a total surprise. My buddy was trying to pull the codes, and it would not read anything. We checked the website and there was an update for it. After the update, it starting reading codes and live data without a problem!
Old Nov 8, 2012 | 04:20 PM
  #54
radmacks's Avatar
radmacks
I have a 2002 7.3l and have read codes no problem using both the cheap generics from ebay listed below. In fact not only do I read codes but I stream data and view it in real time.
I may be mistaken but the last time I checked AE, Superchips and Actron did not make compatible dongles/software with android?
The title of the thread was android scanner application .
I have no doubt the three listed are great for reading codes but the thread started out for Android based compatible dongles and software. To answer the original question asked these two links listed below work for the OBD2 7.3. remember Ford had obd1 too.
New ELM327 Interface Bluetooth OBD2 1996 US EOBD 2001 EU Auto Scanner V1.4 Blue | eBay
ELM327 v2.0 Bluetooth Wireless OBD2 OBDII Interface Diagnostic Scanner Car Tool | eBay
1.) AE
3.) Actron CP9580
Old Nov 8, 2012 | 04:23 PM
  #55
empiretc's Avatar
empiretc
Like stated, they were found to work with the later year 7.3l trucks. you will not have those same results on a 99, guaranteed. So you cannot just say "yes, they all work".
Just throwing options out there for people looking for something cheaper. Is it still possible to hijack a 7+ month old thread?
Old Nov 8, 2012 | 05:06 PM
  #56
SpringerPop's Avatar
SpringerPop
David,
Beware the dreaded thread hijack police!
I'm afraid we're now in for a Whole New World!
Pop
Old Nov 8, 2012 | 06:23 PM
  #57
empiretc's Avatar
empiretc
Pop
"Hey, careful, man, there's a beverage here! "
Old Nov 8, 2012 | 07:33 PM
  #58
SpringerPop
I didn't mean for it to shoot out of your nose like that!
I sure hope it wasn't carbonated, and it didn't end up in your keyboard.
Pop
Old Nov 9, 2012 | 03:29 PM
  #59
Mark Alligood's Avatar
Mark Alligood
Has anyone used this one?
Vizion Wireless Monitor
Is it worth the money? I was considering using this setup with an android tablet. I have a few ideas (that i think are good but your opinions may vary) but I have been a little skeptical about dumping the cash to pick it up and I haven't been able to find anyone that has actually purchased it.
Old Nov 9, 2012 | 03:59 PM
  #60
empiretc's Avatar
empiretc
That essentially looks the same as the Bluetooth ELM327 adapers, except that they integrated the Wifi hotspot to it instead of BT.
This makes it no better than any of the $10 ones on fleabay. It is all in the software, and quadzilla has been around for a while- with not so great reviews. Years ago they promoted the quadzilla commander, and this looks like a cheaper alternative to that. Do some research.
If your truck is an 02+, it would be in your best interest to get a $10 vGate and try it out. You can use the Torque app free, but for $5 it worth it since you will be able to run all kinds of tests on anything with an OBD2 port (94-03 7.3l is a special creature).
