question or 2??
Old Mar 30, 2012 | 11:23 AM
  #31
bcaughhorn's Avatar
bcaughhorn
Originally Posted by kawcrasher
You could have been off one range on the meter. That would give 6 good and 2 bad.
You went over my head. What do you mean? I'm a pipefitter/ pipewelder. Electrical is out of my range
Old Mar 30, 2012 | 11:41 AM
  #32
PaysonPSD's Avatar
PaysonPSD
If the meter isn't on the right ohm range the 11 and 13 readings might be 1.1 and 1.3 and the 35 and 54 might be 3.5 and 5.4.
Old Mar 30, 2012 | 11:43 AM
  #33
bcaughhorn's Avatar
bcaughhorn
The new one ohmed .9 same setting
Old Mar 30, 2012 | 01:14 PM
  #34
PaysonPSD's Avatar
PaysonPSD
Maybe you just didn't notice the decimal point when ohming the old GPs.
It's just strange that ALL the GPs would be bad.
You have 8 new GPs so you might as well install them.
While you have the VCs off you can retorque the rocker pedestal bolts and the injector hold down bolts
Also a good time to let it idle and watch the injector oil discharge.
Old Mar 30, 2012 | 01:54 PM
  #35
bcaughhorn's Avatar
bcaughhorn
i thought that too so i double checked them. 11 was the lowest. i worked on the driver side. changed all 4 and cleaned the vc up and cleaned out the intake tube. checked the turbo for any play. its tight zero play. also noticed the plug at the base of the turbo pedestal is unpluged. i ran out of time before i made it to the pass side. gotta pick the kids up from school and bus stop then we are going out of town for the weekend.
Old Mar 30, 2012 | 01:57 PM
  #36
bcaughhorn's Avatar
bcaughhorn
ill get on the pass side next week sometime.
dome light problem solved too. the relay was gone.
there was also another relay under the hood gone so i put one it it too now my a/c blows from the vents too.
i had a fairly productive day.... i think
Old Mar 30, 2012 | 02:19 PM
  #37
PaysonPSD's Avatar
PaysonPSD
Yes, you have had a productive day.
Have a good weekend and safe trip.
Old Mar 30, 2012 | 02:23 PM
  #38
bcaughhorn's Avatar
bcaughhorn
Thank you sir. I appreciate the help
Old Mar 30, 2012 | 03:17 PM
  #39
bcaughhorn's Avatar
bcaughhorn
just read the thread for the overhead console. it took me a total of 12 minutes from start to finish to get it back on. very easy job..
Old Apr 2, 2012 | 08:58 AM
  #40
bcaughhorn's Avatar
bcaughhorn
forgot to set my alarm.........
so back to work on the truck..
fixing to get the other 4 glow plugs in and the other half of the .50 mod.
gonna clean up the ic pipes and vc's mite even give them a squirt of paint too.
Old Apr 2, 2012 | 11:21 AM
  #41
bcaughhorn's Avatar
bcaughhorn
Yes.
With the engine cold, Pull the valve covers, start it and watch the oil discharge ports. They should all flow about the same.
well i pulled the pass vc and changed the gp's. fired it up (its not cold) and watched it run for a minute. it wasnt cold. its kind of hard to see the back 2 injectors discharge but it looked like there was more oil coming from both of them. the front injector is a different color, does that mean its been changed? i think 1 or 2 on the driver side were the same color as that one too.
Old Apr 3, 2012 | 07:58 AM
  #42
bcaughhorn's Avatar
bcaughhorn
my buddy said to check voltae from the ficm. How do I do this? Or is that just on the 6.0?
notiones
Mar 5, 2009 10:49 PM
Eric H
15
Dec 12, 2008 09:19 AM
johndeeregreen_21
15
Oct 26, 2007 07:58 AM
fbca7
15
Feb 6, 2007 10:19 PM
Greenscape
Jan 31, 2005 02:37 PM
