how to set timing
how to set timing
well i need to set my engine in time, its not the cams its the distributor part, sorry im so vague but i have hardly any idea what im talking about here, my grandpa is going to help me and he knows exactly what to do, just needs the exact numbers as to what it needs to be set to and he said somthing bout having to discconnect somthing to reset it?
Right. Normally a engine runs alittle better when the timing is advanced alittle over factory. And yes forward. If your chain has slack, you might have to go to 15*. If you go too far, it will spark knock when you drive it, just back the timing down till it stops.
Also you spout will be located at the distributor, or on the drivers side quarter panel near the fire wall.
This writeup from Ryan, aka fireguy50, might help you out: Fuel Injection Technical Library » Setting the timing
VintageBlueOval
05-05-2004 10:47 PM
iskybantilus
04-28-2003 07:34 AM
