1995 302 swap to 351, transmission help
Ok guys I am a noob here and need some help..
I have a 1995 f150 4x4 with a 302 and 4r70w trans.
I have a 1995 351w sitting in the garage getting rebuilt.. My current transmission is acting up. I looking to buy another one one that has been recently built or need redone. As this truck is a daily driver.
Anyways I have found a guy locally that has a 1996 e40d out of a 4x4.. Now will this work in my truck when I do the 351w swap? I am unsure about the electrical connections, cross member, whether or not the transfer case will bot up, and how about the drive shaft length?
Is it worth the change or should I hold out for another 4r70w?
Any help would be greatly appreciated!
Thanks
Thanks
on
E4OD is not compatable with the electronics in our truck, fix or replace the 4r70w. But before you rip it out what exactly was it doing? You have to understand that both of these transmissions are COMPLETELY computer controller and ANY sensor issue anywhere on the powertrain(engine, transmission, rear axle) will put the computer in limp mode which makes the trans do all sorts of unusual things.
Thanks for the fast reply.. It is just first gear when taking off from a stop more so on a incline and a very slight incline at that.. But it slips.. Sometimes is does it other times it doesn't.. So I was going to worry about it when I done the swap. If I put in in first and then shift into second it doesn't do it..
