setting timing with fuel injection
Old Apr 26, 2003 | 08:42 PM
iskybantilus's Avatar
iskybantilus
hey ya'll
i know to set timing in a fuel injected vehicle .. you have to discconect spout connecter, so dont think i'm being that stupid . i was just working on my 86 town car .. which is same setup as a truck, basically, and had to replace the distributor. for some reason when i disconect the spout it wants to stall. can anyone set their timing to base and then reconect spout, and check the timing ... so i can try to set mine. or if anyone has any other ideas. thanks
Old Apr 26, 2003 | 09:46 PM
c96drumm's Avatar
c96drumm
Maybe you can get it in the ballpark with spout connected then disconnect spout for final setting.
Old Apr 26, 2003 | 09:54 PM
Racerguy's Avatar
Racerguy
Try setting it to about 15 or 20 degrees BTDC with the SPOUT in and it should run well enough to pull the SPOUT to set it properly.
Old Apr 26, 2003 | 10:19 PM
CLUMP's Avatar
CLUMP
Did you try twisting the distributor -advancing or retarding the timing, then pulling the spout connector.The eec 4 pulls some timing out at start up, perhaps its out of range.I always pulled the connector with the engine off and warmed up then set the timming to 10 degrees btdc reconnected it then started it up. Sounds like you need to play with the distributor some. Spout or (spark out) basically controls your ignition advance, so if the operating conditions call for advance and your distributor is way off it may cause it to stall. hope this helps
Old Apr 27, 2003 | 12:33 AM
steve83's Avatar
steve83
Follow the instructions on the emissions sticker. If you can't find yours, check the junkyards and bring a camera.
Old Apr 28, 2003 | 07:34 AM
iskybantilus
all good receomendations, but i did all that stuff pretty much. i have it set pretty decent, and it drives good, just feels like its a hair off. i'll prolly go mess with it agian this weekend, after having put a few hundred miles on it, maybe it was just being bitchy after sitting for 4 months. its just one of them strange things i guess.
