Hey guys,
I have an 86 F250 that was originally a 302 EFI but the motor went. Found another small block that runs for $400. The motors in but its not setup for EGR, nor do i want it to be. All i have is the fuel injected intake, which i have the bottom half on, and i dont know what goes where.... Can someone help?
What do you mean "the motor is not setup for egr"? All engines since the early 70's were setup for egr, and the motor you took out was also. All you have to do is transfer all the stuff from the old engine over to the new engine. If you have forgotten how it all goes together, sorry I can't help you there.
I think your asking how to hook up your EFI without the smog equipment, right? If that's it I don't think you can. The computer will be looking for the input from the various sensors and such and it wont know what to do without there input. As for JUST the EGR, I'm not sure. The valve itself isn't monitored by the computer I don't believe, but it might through off the O2 sensors.
OK, now I understand, the heads on the "new" motor doesn't have EGR ports. If your setting it up as an EFI motor, I don't really know if you can eliminate the EGR and still have the motor run properly.
