EGR Block off
Old May 5, 2010 | 02:35 PM
jjarboe01's Avatar
jjarboe01
EGR Block off
Hey all, Just wanted to throw this out there - I have a 95 I-6 motor, the EGR valve had gummed up the intake pretty badly over the years. I took a piece of sheet metal, cut it to *rough* size, and placed it between the EGR valve and the intake. I have to say, on longer hauls, this drops the intake temp by 10-20 degrees and it seems to be getting about 3-4mpg better on drives over 75 miles. Just wanna throw that out to some who haul a lot and like to keep the engine compartment temp down.
Old May 5, 2010 | 02:48 PM
LCAM-01XA's Avatar
LCAM-01XA
Actually that's quite interesting, as what I noticed with my old 302 was just the opposite - higher operating temperatures and more fuel burnt. The primary reason for the EGR is to allow the PCM to advance the timing more and back off on the fuel, with no EGR it will hold back on the timing and fatten up the fuel mixture to make sure you don't risk detonation or running too lean, and that's exactly what mine was doing. I'm usually not a fan of emissions controls, as a matter of fact I firmly believe that EPA is the worst thing that ever happened to the US automotive industry, but the EGR is the one emissions system that I do like... unless it's in a diesel of course, then it sucks, lol.
Out of curiosity, did you leave the EGR valve harness unplugged? Does that not give you a check engine light?
Old May 5, 2010 | 02:58 PM
jjarboe01's Avatar
jjarboe01
left the egr hooked up and all, computer still operates it, it just does nothing and the truck runs great.
Old May 5, 2010 | 03:01 PM
LCAM-01XA's Avatar
LCAM-01XA
The computer should actually know the EGR ain't working properly by the readings of the O2 sensors, but hey, if she runs better now that's all that matters!
Old May 5, 2010 | 03:53 PM
mprice's Avatar
mprice
If it was me I'd be really wondering why there was junk like that in the exhaust.
Superdave
13
Dec 26, 2019 04:04 PM
justinandyvette
Jan 2, 2014 04:59 PM
loubell
Jan 18, 2011 07:23 AM
jbk
May 10, 2010 11:58 AM
Truckin Bob
Mar 20, 2005 07:11 PM
