A question about pulling the codes..
Old Mar 28, 2012 | 08:05 AM
oldfart's Avatar
oldfart
Fellers I'm going to pull the codes on the 1986 F 150/302 this weekend and read the instructions from several locations. Many thanks by the way for all the help. Anyways since I'll be doing this alone I got to wondering....can I hook up the test light and NOT hook up the ground at first. Then reach inside the cab, turn on the ignition switch then go and ground the proper terminal and procede with the test??? Or does it have to be grounded and then turn on the ignition switch and watch the testlight from inside the cab?? I'm just pondering. Thanks! Audie...the Oldfart..
Old Mar 28, 2012 | 03:25 PM
81ChopTop's Avatar
81ChopTop
I believe it takes a couple of seconds for the light to start flashing....OR you could hook up longer leads and have the light inside the cab with you.
Old Mar 28, 2012 | 04:23 PM
ctubutis's Avatar
ctubutis
IIRC it's around 10 seconds for the light show to begin.
Old Mar 29, 2012 | 12:26 AM
kedwinh's Avatar
kedwinh
What I do is, hook the test light up then set it so I can see it from the drivers seat. Just looking thru the gap between the bottom of the hood and cowl area.
crandallf150
Oct 16, 2016 09:55 PM
Virto
17
Jun 2, 2007 10:52 PM
tvulcan
Bronco II
May 20, 2005 07:55 PM
RyanMiller
Apr 8, 2005 09:00 PM
CMazz
1983 - 2012 Ranger & B-Series
May 3, 2004 12:55 PM
