NEED HELP!!!
Old Mar 27, 2012 | 07:20 PM
86--F250's Avatar
86--F250
NEED HELP!!!
Hey guys,
I have an 86 F250 that was originally a 302 EFI but the motor went. Found another small block that runs for $400. The motors in but its not setup for EGR, nor do i want it to be. All i have is the fuel injected intake, which i have the bottom half on, and i dont know what goes where.... Can someone help?
Old Mar 27, 2012 | 08:02 PM
82f100460's Avatar
82f100460
Not really understanding exactley what your question is or what you need help with.
If your old 302 went bad and you have a new one in....everything should swap over the same.
Old Mar 27, 2012 | 08:04 PM
Franklin2's Avatar
Franklin2
What do you mean "the motor is not setup for egr"? All engines since the early 70's were setup for egr, and the motor you took out was also. All you have to do is transfer all the stuff from the old engine over to the new engine. If you have forgotten how it all goes together, sorry I can't help you there.
Old Mar 27, 2012 | 08:16 PM
kedwinh's Avatar
kedwinh
I think your asking how to hook up your EFI without the smog equipment, right? If that's it I don't think you can. The computer will be looking for the input from the various sensors and such and it wont know what to do without there input. As for JUST the EGR, I'm not sure. The valve itself isn't monitored by the computer I don't believe, but it might through off the O2 sensors.
Old Mar 28, 2012 | 07:29 PM
86--F250's Avatar
86--F250
sorry,
what i meant was that the head ports are blocked...and i want to delete the egr
Old Mar 28, 2012 | 09:36 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
Why would you want to delete the EGR?
Old Mar 29, 2012 | 12:11 AM
kedwinh's Avatar
kedwinh
OK, now I understand, the heads on the "new" motor doesn't have EGR ports. If your setting it up as an EFI motor, I don't really know if you can eliminate the EGR and still have the motor run properly.
jjarboe01
May 5, 2010 03:53 PM
cscott952
Mar 28, 2008 02:14 PM
moritz1024
1978 - 1996 Big Bronco
Oct 31, 2005 01:47 PM
Dustin_86
May 1, 2005 11:26 PM
kane
Oct 1, 2004 12:11 AM
