help id /decode
Old Mar 27, 2012 | 07:18 PM
schoo's Avatar
schoo
help id /decode
1964 f250 4x4 f26jr54110
warranty #
120 f260 181 f b4
6800 114 3600 743386
transfer case is model-24 spicer
serial# 546142
b/m 300205 6
def has a rt side tag on one side reads use limited slip lube
tag on other (left side) is hard to make out looks like
C4TA-08
2493-8 5-64 4.56
no other id plates what is manufacturer(who done it)?
? how to id transmission? where is id plate on tranny? have not looked at front def yet got dark and cold
Old Mar 27, 2012 | 08:43 PM
schoo's Avatar
schoo
starting to have concerns about my 64' 4x4 above
1.main frame height about 1" taller than my 64 f250 2wd parts truck
2. the steering box is a lot bigger
3. are all f250 4x4 frames bigger?
4. but dry fit the fenders, doors, and hood all seem to fit good?
Old Mar 27, 2012 | 11:34 PM
jhooch's Avatar
jhooch
Look at the VIN that's actually stamped on top of the RF framerail, see if it matches the VIN you posted. You'll probably have to do some scrubbing to find it.
Old Mar 28, 2012 | 08:44 AM
schoo's Avatar
schoo
good idea found that the other day
needs cleaning
Old Mar 28, 2012 | 09:47 AM
schoo's Avatar
schoo
got some ??
body code = 181 whats that=
trans= F =?
axle = B4=?
dso= 743386=?
any help?
thanks roy
Old Mar 28, 2012 | 01:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by schoo
1964 f250 4x4 F26JR544110 / 120 / COLOR code omitted / F260 / 181 / F / B4 / 6800 / 114 / 3600 / 743386
F26 = F250 4WD
J = 223 1V I-6.
R = San Jose CA Assembly Plant.
544,110 = 1964, assembled May 1964.
120" Wheelbase.
COLOR code omitted.
F260 = F250 4WD, 6,800 lbs. GVWR
181: 1 = Not listed for F100/350's. Verify it's a 1 as it could be an L / 81 = 81A Standard Cab.
F = Borg Warner T-98 4 Speed Manual Transmission.
B4 = Spicer/Dana 60 Rear Axle / 4.56-1 / Limited Slip / 5,200 Rear Axle Capacity.
6,800 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,800 RPM (223 I-6).
743386:
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
3386 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
When there is no COLOR code, the vehicle is painted a non standard color per the original purchasers request. This makes the vehicle a Domestic Special Order.
Old Mar 28, 2012 | 06:10 PM
schoo's Avatar
schoo
you'r correct again nd F26JR544110 missed that
this matches #on the frame
4.56 rear 4.55 can't find a # on def's
where is the tag or id on that tranny
Old Mar 28, 2012 | 06:20 PM
schoo's Avatar
schoo
body # 181 no L or I it's an one eight one
the framerails is taller and wider than 64 f250 2wd
Old Mar 28, 2012 | 06:35 PM
NumberDummy
544110 = 1964, assembled May 1964, edited into post 6.
The original front AXLE ID tag was under one of the bolts that retains the inspection cover to the housing. Many are missing by now.
Ditto for the Spicer/Dana rear AXLE ID tag.
The TRANS ID tag was originally bolted to the right side of the case. Many are missing by now.
2WD's do not use the same frames as 4WD's.
C3TZ-3504-S .. Steering Gearbox / 1963/65 F100/250 4WD / 1963/66 F350 / 1966 F250 4WD.
There is no listing for #1 upholstery color, except for F500/1100's.
Old Mar 28, 2012 | 08:21 PM
schoo's Avatar
schoo
thanks bill for the help!!
roy
JDBeck23
Jun 18, 2017 09:47 AM
Montecz
Dec 31, 2014 12:35 AM
laynejc
Apr 2, 2009 10:26 PM
firefighter1
Dec 5, 2008 09:22 PM
frty7ford
Feb 4, 2005 09:32 AM
