Need A/C help
Old Mar 27, 2012 | 04:47 PM
shadows4's Avatar
shadows4
Need A/C help
2000 Excursion 142,000 miles. A/C runs fine on Max setting but any thing else and it just blows hot air. Tried searching but maybe I wasn't using the right search terms cause I couldn't find squat! Any help is appreciated thanks, John
Old Mar 27, 2012 | 05:15 PM
swheeler's Avatar
swheeler
The fact that it works on max tells me that the compressor, charge, and compressor clutch are okay. I would take a guess that something is going wrong in the dash, behind the climate control. But, that is just a guess.
Old Mar 27, 2012 | 07:52 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
Sounds like a blend door problem.
Old Mar 27, 2012 | 09:07 PM
Forest's Avatar
Forest
Yes. Check all the vacuum lines. Maybe one is cracked or slipped off. There should be a manifold connection on the V10. Pull this off. Use a hand vacuum pump (or suck on it) to see if it can "hold" a vacuum.
Old Mar 28, 2012 | 05:15 PM
SpringerPop's Avatar
SpringerPop
I believe the Excursions had, from the factory, what us truck guys add on as a mod.
It's a vacuum-controlled valve in the heater-hose line that shuts off coolant flow to the HVAC box during MAX mode. I suspect that is a major clue here.
When you're in MAX mode, there is no "heater" action inside the box, and you get cold. Once you leave MAX mode, the coolant again flows to the box, and you get heat. There's more heat available from the heater than there is cold from the A/C, so you get warm.
What's supposed to happen during A/C is the blend door should direct most of the air flow through the evaporator coil, and not through the heater core (unless, or course, you WANT it at eighty degrees on a hot day). If the blend door isn't working properly, it goes through the heater core instead. Sound like what's happening?
So, I suspect your blend door isn't operating. It's vacuum controlled, and there are lots of threads (though not many recently) on fixing a blend door problem.
Like always, "Search" is your friend.
"blend door" is the subject to plug in.
The guys posting above have steered you in the right direction.
I've attached a couple of PDFs for you to read to get an idea of how the system works.
Pop
File Type: pdf
File Type: pdf
Old Mar 28, 2012 | 05:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Replacing the blend door with the factory part is expensive and the new one will fail, too. I installed a Heater Treater on several vehicles. It's a MUCH better part and it's easier to install, too.
They don't list one for Excursion, but they do for F250+. I think they are the same, you many want to contact them to be sure.
F250+ - Ford
Old Mar 28, 2012 | 07:54 PM
Sunline Fan
F250+ - Ford
Do the trucks have venting that go on the floor and vent out under the front seats?
Old Mar 28, 2012 | 10:37 PM
SpringerPop
Uhhh, no.
Pop
stephenfaustin
Jun 4, 2013 04:50 PM
dmueller71
16
Dec 17, 2009 07:44 PM
dpleva
Oct 28, 2009 01:08 PM
JVAN
Jun 28, 2005 12:59 PM
levilevi2
Sep 6, 2002 12:06 AM
