A/C Compressor
Old Jun 4, 2013 | 04:21 PM
stephenfaustin's Avatar
stephenfaustin
A/C Compressor
Okay, looks like it is time for a new a/c compressor. How difficult is it to put a new compressor in? Any tips or tricks I should know?
stephenfaustin
Sorry, 1995 F-150 5.0.
Old Jun 4, 2013 | 04:50 PM
norfolknova's Avatar
norfolknova
Compressor is straight forward as far as installation, it is all of the other details that can get you.
Replace the Orifice tube and the Accumulator/dehydrator. Flush the condenser, Evaporator and all lines. After you seal the system back up and add oil, you need to evacuate the system and check for leaks.
If you do not have a vacuum pump, or access to a vacuum pump you will have to find a shop that will evacuate it for you. If it holds vacuum then you are ready to charge, if vacuum does not hold pressure test with nitrogen to find leak, fix leak, and pull vacuum again
Good Luck
Matt
Danger_Dave
Oct 11, 2008 05:01 PM
mneal
1997 - 2003 F150
May 30, 2007 11:16 PM
chaiyzbrown
May 24, 2005 09:29 AM
Piffery1
Garage & Workshop
Dec 30, 2004 10:05 AM
levilevi2
Sep 6, 2002 12:06 AM
