P0299 code and preparing to pull turbo
Old Mar 25, 2012 | 01:52 PM
Dans2Fords's Avatar
Dans2Fords
I've been getting the P0299 code off and on since I've gotten the truck 3 months ago.
Truck is an 05 with 64,000 miles so I'm assuming the turbo needs to be cleaned. The truck was never used for towing or put to any hard work so I assume rust has built up.
Money is kind of tight at this point but is there any major things I should do when I pull the turbo to clean it?
I've also seen the guide to cleaning the turbo in the tech folder, but is there an easy guide to pulling the turbo?
Thanks everyone.
Old Mar 25, 2012 | 01:57 PM
npccpartsman's Avatar
npccpartsman
Soak the turbo mount bolts with PB Blaster before you pull them. No real easy trick to pulling it. Have you checked all your exhaust and CAC pipes for leaks??
Old Mar 25, 2012 | 04:59 PM
Dans2Fords's Avatar
Dans2Fords
Yes, exhaust is good and the CAC are worn and I will be replacing them, but they have not cracked or anything.
I just didn't find a guide to pulling the turbo...ie unbolting the alternator, etc. I wanted to ask everyone here who has pulled their own turbo.
Thanks.
Old Mar 25, 2012 | 05:58 PM
npccpartsman
Thanks.
I don't usually pull the alternator but it does make it easier to wiggle out. You do have to loosen and roll back the wiring harness that's over the turbo. Best I can tell you is that the turbo "screws" in and out with a twisting motion. Once you figure it out it doesn't take long. Cheezit has it down to about 15-30 minutes. Takes me an hour with hand tools but I'm slow.
Old Mar 25, 2012 | 07:17 PM
BLADE35's Avatar
BLADE35
The Bolts maybe cooked in there and seized as tim mentioned PB Blaster and use a 6 point wrench to break them free especialy the Back bolt PIA
you might can use a socket & ratchet on the fronts Only because you can see it to keep it all lined up straight But again use ONLY a 6 Point socket
and then read this
https://www.ford-trucks.com/ford-man...%20Removal.pdf
Click here^^^^^^^^^^^^^^
Its not to bad Just the Bolts Gave me the hardest time they were cooked and seized in there Good mainly the Back Bolt really SUCKED for me. My turbo will never have that bolt installed again
Use anti seize on all of it going back together on bolts and Marmon Clamps/Valleys alittle slip-n-slide helps alot
Old Mar 25, 2012 | 09:07 PM
kidoo's Avatar
kidoo
I shop around for a 6 point wrench but could not find one. Where do you get it?
Old Mar 25, 2012 | 10:04 PM
BLADE35's Avatar
BLADE35
I got mine at Sears
Old Mar 26, 2012 | 07:51 AM
kidoo's Avatar
kidoo
Thanks, we have a sears store here, so I will check this out
Old Mar 26, 2012 | 11:50 AM
Dans2Fords's Avatar
Dans2Fords
Awesome, thanks Benny.
I had seen a video, but the pulled the oil filter housing, dropped the alternator down and did a few other things, but if it can be done without having to do all that, I'd rather go that way.
Old Mar 26, 2012 | 12:43 PM
mblanken881's Avatar
mblanken881
Any store that sells hand tools. Probably one of the most common tools.
Old Mar 26, 2012 | 04:06 PM
raptor131's Avatar
raptor131
The best tool for this is a long pry bar to get the base of the turbo off the oil drain tube, it is so heavy and is well seated to the up pipes that the pry bar will help alot
Old Mar 26, 2012 | 06:18 PM
npccpartsman
You don't have to pull either but pulling the alternator is relatively easy. The oil/fuel filter housings are a PIA to get off. I do it without pulling either. I equate it to one of those brain teaser puzzles where you're trying to get entwined metal rings apart. Once you know the "key" it twists right out.
coolfeet
Mar 21, 2016 08:17 AM
green_95
Mar 7, 2016 01:56 AM
nutfarmii
Jun 9, 2009 06:17 PM
4bigred
Nov 8, 2008 01:38 PM
wb6anp
Feb 26, 2008 11:49 PM
