Sticking Turbo 299 code
Old Mar 20, 2016 | 06:23 PM
coolfeet's Avatar
coolfeet
Every time I climb a grade, I get the 299 code. My VGTs go to 15 or 85. Does this indicate my turbo is sticking?
Old Mar 20, 2016 | 06:36 PM
69cj's Avatar
69cj
Sure does. Clean, rebuild, replace center section or replace entire turbo. Disassembly will tell all. Three times on my 05 the turbo had to be replaced.
Old Mar 20, 2016 | 07:02 PM
WatsonR's Avatar
WatsonR
that code pops when the turbo is under boosting at 4lbs or more and for 5 seconds or longer.... it's sticking.
Old Mar 20, 2016 | 07:57 PM
coolfeet's Avatar
coolfeet
I plan on removing the turbo and/or cleaning it. I found a Ford MasterTech that will remove and clean the turbo for $300. Once the turbo is removed, it's easier to remove and replace other failure points like the EGR and oil coolers on the 6.0.
Engine EOT and ECT are in spec but the spread is high enough to concern me (12 degrees).
I have the E350 Super Duty van. It's hard to get at anything in the engine compartment. Once the turbo is removed, I may decide to do more since I am already "in there".
Old Mar 21, 2016 | 08:17 AM
navistarnut's Avatar
navistarnut
12 is within spec, yes, but only a matter of time before a new cooler and like you stated the turbo is out so you are that much further ahead already. You could install a coolant filter I suppose to buy some more time.
Are the EOT and ECT about the same after a cold soak?
Dans2Fords
Mar 26, 2012 06:18 PM
05Xdriver
Nov 15, 2011 10:40 AM
KRDiesel
Apr 13, 2010 03:10 PM
silly34
Jan 20, 2010 12:41 PM
Jeremy2792
Nov 24, 2009 09:21 PM
