Turbo removal
Old Mar 6, 2016 | 01:53 PM
green_95's Avatar
green_95
Turbo removal
Any tips for removing and installing a turbo? Getting ready to do the ebpv and pedestal delete. Was wondering is it best to put turbo and pedestal back on as one piece or should I bolt the pedestal down first and the put the turbo on?
Old Mar 6, 2016 | 02:04 PM
madMatador78's Avatar
madMatador78
Swivels and wobbles are your friend. It has to come out and go in as 1 assembly.
Old Mar 6, 2016 | 02:19 PM
Hussler's Avatar
Hussler
Yes, the pedestal has to be attached to the turbo for installation. don't forget new o-rings.
I used the instructions here ... TikiWiki : Turbo removal 1994.5-1997 PowerStrokes
Once the turbo - pedestal if off check the collector to up pipes as the donuts will probably loose seal. You can put new donuts in or bite the bullet and get some bellowed up pipes and be done with it. Wish I had done that when my turbo was off.
Took me 1.5 days to get the turbo out but with ebpv pedestal delete only took me about 1 hour to reinstall.
Old Mar 6, 2016 | 02:20 PM
MI02SVT's Avatar
MI02SVT
I've taken mine out before by splitting them after the exhaust bolts used a 10mm ratchet wrench for the 4 bolts holding the turbo to the pedestal was pretty easy that way
Edit : or was it 5/16. Can't remember now
Old Mar 6, 2016 | 02:42 PM
z31freakify's Avatar
z31freakify
Check my mod on the stickies called freakify mod. Because I know you got the mod bug fever and your going to remove that turbo a couple of times
Old Mar 6, 2016 | 11:49 PM
BBslider001's Avatar
BBslider001
I need this mod dammit
Old Mar 7, 2016 | 01:56 AM
JSchuricht's Avatar
JSchuricht
You will find the passenger side bolt difficult to get a socket on because you hit the flange on the turbo. It won't help you with the first removal but grind a bevel in the flange on the turbo before you reinstall it. Makes getting the bolt back in much easier and the next removal easier too.
Engalwood
21
Jan 30, 2012 06:14 PM
KRDiesel
Apr 13, 2010 03:10 PM
nutfarmii
Jun 9, 2009 06:17 PM
redneckboy
Mar 30, 2007 11:32 AM
Miller
Dec 30, 2006 07:19 AM
