Sponsored by: Real Truck
Power Sliding Rear Window
Old Mar 25, 2012 | 12:30 PM
Dieselman828's Avatar
Dieselman828
Hey guys, Well I bought the truck about 6 months ago and the rear power window never did work. So its getting summer time and all my windows need to be down, IDK its like a instant chick magnet haha. I've been meaning to fix the window, and finally got around to start it today. I dont believe its the motor because you can hear it trying to crank. I believe I had seen once where the line gets tangled up or something like that. I guess what I need to do is if there is a way to pull the line out and the motor out and then pull the line from the motor and try to put the line back in? Hope this makes since to someone. Thanks for the help!
-2005 F250 Lariat 4x4
Old Mar 25, 2012 | 12:49 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
subscribing
my window works when it wants to. hope someone has an easy fix
Old Mar 25, 2012 | 12:59 PM
GregsSD's Avatar
GregsSD
Check the window track, make sure it doesn't have any dents in it and that it is very clean. You might spray some silicone lube on the track too.
Mine is in perfect mechanical condition but it doesn't take long for dirt and dust to get in the track and really slow the window down because the motor is not very powerful.
Old Mar 25, 2012 | 01:05 PM
Dieselman828
of so i had to re attach the line that gets it open. When it pulls its very weak! But I can find the line for the closing side. Also is the line suppose to connect to the top or to the bottom on the window. Because the bottom appears to be worn out and it wont even think about staying in there. Hopefully I can get this thing running. I can get pics if necessary. Thanks for the help also
Old Mar 25, 2012 | 01:19 PM
Dieselman828
will WD40 work? Im still trying to fish the closing wire down, cant seem to find the dang thing. Anyone I can get the cable off the track to find it? Sorry for the Noob questions
Javier89F150
Jul 23, 2015 01:43 PM
bruno2
Mar 28, 2014 10:01 AM
tpd475
1997 - 2003 F150
Sep 13, 2006 12:47 AM
v6mustangman
May 7, 2006 06:51 PM
kilika77
1997 - 2003 F150
Nov 12, 2005 09:21 PM
