Window motors?
Old Jul 23, 2015 | 11:42 AM
Javier89F150's Avatar
Javier89F150
Window motors?
My 1989 passenger window motor gave out on me, and I was wondering if any window motor out of f150s newer than mine would work?
Only reason I ask is because I went to a local pick a part yard and couldn't find any trucks the same year as mine.
Old Jul 23, 2015 | 01:16 PM
Willz74's Avatar
Willz74
You might try cleaning it out that's what was wrong with mine eventually I'll get to the passenger but that one is just slow
Old Jul 23, 2015 | 01:24 PM
dixie460's Avatar
dixie460
If the motor runs but the window won't move then you just need to replace the plastic rollers inside.
Amazon.com: Dorman 747-409 Power Window Motor Gear Kit for Select Ford/Mazda Models: Automotive Amazon.com: Dorman 747-409 Power Window Motor Gear Kit for Select Ford/Mazda Models: Automotive
Old Jul 23, 2015 | 01:29 PM
Javier89F150
Last I checked the window wouldn't go up (it was stuck with the window down) so I propped the window up with a screw. I'll find out for sure in a few when I get home.
Old Jul 23, 2015 | 01:31 PM
mtrosclair's Avatar
mtrosclair
Or even cheaper you can buy nylon spacers at the hardware store. Mine stripped out, bought $1.50 worth of spacers and now it works great.
Old Jul 23, 2015 | 01:43 PM
Javier89F150
Just got home, the window is currently propped up with a random bar so the window is up all the way. As opposed to the screw, if left a 1 inch opening that the spiders seemed to love!
I also noticed that the passenger door won't unlock through the button...
but I've pressed both the window up and down button and didn't hear/see anything
ddwood55
1978 - 1996 Big Bronco
May 24, 2016 04:09 PM
87wreckerman
Dec 7, 2005 11:07 PM
kilika77
1997 - 2003 F150
Nov 12, 2005 09:21 PM
markmacd
1997 - 2003 F150
Dec 31, 2003 09:32 PM
shotgunner426
Oct 3, 2003 04:06 PM
