I am going to rebuild my power window motors pretty soon. They have the slow laggy movement. I have seen the help kits to re bush them and have heard about the fuel line trick too.
However, here is an issue that I am not sure of what is going on. The driver side window leans back and forth and will bind up. I am not sure what to expect when I get into it so this is why I am asking now. What part breaks in there to cause this? Also can the part be repaired or does it need to be replaced? If so is a JY part or a new part needed?
No, it is 21536. The others are the supports, but the runs are the soft material the glass rides in. You can get it at LMC, JBG, etc. but I would pull the door panel and observe the glass in action before buying.
