Help 352 or 390?
Old Mar 22, 2012 | 08:11 PM
cartef's Avatar
cartef
Help 352 or 390?
I need info i have a motor i was told it's a 65 model 352 this was the number on the head C8AE then 8080R anyone know by the head number what this is? and if it's a good or bad
Old Mar 23, 2012 | 05:11 AM
jowilker's Avatar
jowilker
352 was the only V8 installed in a truck in 65. I could not find any reference to 8080 at all saw some 6090, you want to look again at that? Could be a car engine.
John
Old Mar 23, 2012 | 07:33 AM
baddad457's Avatar
baddad457
Not a 65 engine with those casting numbers, might have read the numbers wrong, C6AE-R's are 66 352 heads
Old Mar 23, 2012 | 07:42 AM
cartef's Avatar
cartef
That's what he said but I'm doubting it. So is it a 390 from what you are seeing?
Old Mar 23, 2012 | 08:52 AM
MIKES 68 F100's Avatar
MIKES 68 F100
c8ae is a 1968 engine
as for what size measuring bore and stroke only real way to tell .
get cylinder to tdc pull a plug and drop a long wood dowel in cylinder mark dowel , remove dowel and turn engine over by hand till cylinder is at bottom insert dowel and mark again . 3.5 = 360 3.75 = 390
Old Mar 23, 2012 | 10:02 PM
baddad457's Avatar
baddad457
Those numbers you posted could also be C8AE-H, which are your run of the mill 68-71 FE heads. Could be either a 360 or 390, both used the same heads.
Old Mar 24, 2012 | 09:04 PM
Ken(Ark)'s Avatar
Ken(Ark)
Probably 360/390 but could be a 352 (3.5 stroke) with later heads , could be a destroked 427 , he he , just sayin could be anything . Like you said , until you measure the bore and stroke ....
Old Mar 25, 2012 | 09:09 AM
1972RedNeck's Avatar
1972RedNeck
My bone stock original '66 F250 4X4 with a 352 has C4AE's. Same as Grandpa's '65 352.
mswift
Jan 11, 2005 04:45 PM
mswift
Sep 11, 2004 12:34 PM
Spudco
17
Feb 12, 2003 06:23 PM
75explorerxlt
Jun 2, 2002 01:04 PM
Phat65
Mar 31, 2000 03:17 PM
