New axel mounting question
Old Apr 28, 2003 | 01:17 PM
rogue69's Avatar
rogue69
I bought a bronco with a 6 inch lift. The axel housing is cracked so I need a new one. The problem is that the axel housing is rotated to make up for the height. With a new axel do i have to re weld the axel mounts so it is at the same angel as the old one.
Old Apr 29, 2003 | 02:07 PM
rogue69's Avatar
rogue69
TTT for me
Old Apr 29, 2003 | 05:32 PM
carrier's Avatar
carrier
I also have a Bronco with a lift (4") and what they did with mine is they use small wedges that tilt the rear a few inches up. The wedges fit in between the spring perch and the springs if I remember right. Check and see if you have small wedges there and if not let me know, maybe I can help - I can at least send pics of my wedges-
Old Apr 30, 2003 | 02:11 PM
rogue69's Avatar
rogue69
Thanks carrier.
I think my cheapest thing to do is weld the axel where it is cracked. I hope it works fine.
Old May 1, 2003 | 02:16 PM
rogue69's Avatar
rogue69
My axel casing is turned up. The break adjust hile is normaly located a t the bottom but on this one it is located forward some.
What do you think.
Old May 1, 2003 | 02:20 PM
SDElwood's Avatar
SDElwood
FTE Remembers
If you choose to weld that axle housing I would also HIGHLY recommend trussing the axle too. The axle cracked for a reason, and the weld will be your weakest link now. So spend a little time and truss it up - with a 6" lift you have plenty of room.
Old May 1, 2003 | 02:25 PM
rogue69's Avatar
rogue69
Thanks mike.
Two questions, first of all I always thought a weld is stronger than the metal . And second how do you truss it up?
thanks travis
Old May 1, 2003 | 02:39 PM
SDElwood's Avatar
SDElwood
FTE Remembers
Welds are strong, very strong, but when you weld you introduce heat, and unless you are a very good welder you may not get the weld in the entire depth of the crack.
As far as trussing goes, just use some square tube, flat stock, whatever you have and weld from each end of the axle up and over the pumpkin and put uprights every so often. I don't have any pics of my trusses on this computer, or I'd post one. If I think of it, I'll try to take one tonight.
Old May 1, 2003 | 02:41 PM
rogue69's Avatar
rogue69
Thanks mike. Another option is changing to a dana 60 but I cant afford it im sure. I would like to see your pictures. I have a brother inlaw who is a pro welder.
Outlaw56
Feb 25, 2017 05:22 PM
Outlaw56
29
Jan 27, 2016 10:54 AM
Outlaw56
Mar 2, 2015 07:37 PM
No Bad Days
Jun 25, 2009 07:30 PM
weswes01
Offroad & 4x4
Apr 17, 2006 05:49 PM
