4R100 failures
Old Apr 25, 2003 | 11:39 PM
jct's Avatar
jct
4R100 failures
1999 V-10 4R100 F53 Motorhome – On a downhill run, I downshifted to 2nd for braking assistance and the motor home acted as if the transmission was in neutral. When I pressed hard on the acellator, the transmission downshifted and provided the usual braking assistance. About three hundred miles prior to the downhill event, the transmission had massive slippage while starting off from a rest area. It finally lockup in OD and drove normally with several stops and starts, until the downhill event. Currently, Reverse, Neutral, and Drive provide no movement. 2nd and 1st will move forward with considerable slippage. Any ideas on my transmission problems?
Old May 1, 2003 | 07:21 PM
jct's Avatar
jct
4R100 failures
All these symptoms were caused by a center support bearing failure. The transmission shop indicated it was just a bearing failure, no excess heat or abuse was found during the rebuild. Total cost $2850 with a 12 month warranty.
Old May 1, 2003 | 07:57 PM
AggiePSD's Avatar
AggiePSD
4R100 failures
They changed the center support bearing setup back when the transmission was the E4OD to eliminate those kinds of problems. Must have been something unusual.
Old May 1, 2003 | 09:53 PM
jct's Avatar
jct
4R100 failures
The transmission rebuilder indicated early units contained a bushing and the assembly was upgraded to a bearing around 1996-1997. My transmission had the bearing assembly.
volwing1
All Things Towing
27
Jul 27, 2021 01:41 PM
kameronth
Feb 22, 2021 02:19 PM
bendmac
Oct 14, 2019 02:28 PM
brushfit
Feb 19, 2016 10:08 AM
tinytrixie
Feb 21, 2005 10:41 PM
