Vacumme Leak
Old Mar 13, 2012 | 11:01 AM
Chrisv2285's Avatar
Chrisv2285
Vacumme Leak
Do yall know where the electric vacumme pump is on a 2004 f250 6.0l....my 4x4 does not want to engage without locking the hubs..have any of yall had this problem before, they said its a leak in the hose somewhere..
Old Mar 13, 2012 | 05:17 PM
epfire#233's Avatar
epfire#233
I'm having the same issue. Texastech_diesel sent me the following response. Check out the video located in the second weblink. It should help you diagnose the issue.
Vacuum leak somewhere. If it's all the time it could be an unplugged vac line on the heater valve or a dead pump, if it's intermittent or tied to using 4x4 it could be a leaking hub seal, broken hub line, or a bad pulse lock solenoid.
https://www.ford-trucks.com/forums/11...l#post11311531
https://www.ford-trucks.com/forums/11...n-defrost.html
https://www.ford-trucks.com/forums/11...l#post11120913
Good luck!
Old Mar 13, 2012 | 07:12 PM
wulfman's Avatar
wulfman
It could be a leak anywhere but most of the time it is the hub seals that leak. Mine leak and engage sometimes and not sometimes . I just lock them manually and don't worry about it , but i also know that they are locked this way.
Old Mar 13, 2012 | 08:15 PM
Chrisv2285's Avatar
Chrisv2285
i checked the hoses and there good...i think its the vacuum canister.. there is a little plug on the side and put my finger over the holes on the plug and it stops pumping, how do i know if my canister is bad?
TexasA&M
Feb 17, 2015 01:48 PM
twayne85
Mar 20, 2012 02:03 PM
cory5517
16
Jul 31, 2011 12:00 PM
stroken
May 21, 2010 06:50 AM
preppypyro
36
Aug 18, 2009 10:07 PM
