dash lights
Old Mar 5, 2012 | 05:37 AM
charlie branham's Avatar
charlie branham
2nd Gear
dash lights
My dash lights quit working. The blinkers still work and high beam indicator. No gauge lights. I checked connections and changed the headlight switch. I do have tail lights but noticed the fan blower quit as well. Is there a common ground? The fuses seem to be okay as well.
Old Mar 5, 2012 | 07:04 PM
Blown 331's Avatar
Blown 331
No common ground that I'm aware of, could be coincidence. The same lights you are describing quit working on my highboy. The problem was the rear plastic of the gauge cluster was so brittle that the bulb holders were no longer able to screw into the plastic. I replaced that rear plastic housing with one from an 80s van.
Old Mar 5, 2012 | 08:19 PM
fmc400's Avatar
fmc400
MSEE
Have you verified continuity of the dash light fuse (either a beep check, or checking for power on both sides with the lights on)? There is very litte electrical work you can do without a multimeter.
The blower motor and dash lights are not related.
Does the light on the left side of the dash (that illuminates the headlight and wiper controls) work? What about the one behind the heater controls? Or is the problem isolated to just the gauges?
Old Mar 17, 2012 | 10:27 PM
conoso's Avatar
conoso
I'm having the same problem. The lights work on the headlight switch and the control panel for the ac/heater. The left turn signal works but other then that the gauges will not light up.
Old May 4, 2012 | 08:41 PM
highguy2012's Avatar
highguy2012
If anyone ever figures this out,
I have been through:
3 clusters
1 wiring harness
2 light switches
My dash lights still dont work, and my heater blower does not sound heathy...
Can I add this function specifically without out affecting the rest of the cluster? anyone done this?
Old May 5, 2012 | 06:38 AM
fmc400's Avatar
fmc400
MSEE
I don't understand your question; can you clarify?
Old May 5, 2012 | 07:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The problem was the rear plastic of the gauge cluster was so brittle that the bulb holders were no longer able to screw into the plastic. I replaced that rear plastic housing with one from an 80's van.
1975/79 F100/350, 1975/80 Econoline and 1978/79 Bronco came with instrument cluster backs that were made from a COMPOSITION material that can TURN TO DUST before your very eyes!
In 1981, FoMoCo came out with hard plastic cluster backs for Econolines. These were also used as the service part replacements for the 1975/80 POS composition cluster backs.
Some of the POS composition cluster backs were replaced with the hard plastic cluster backs under warranty, some via 'customer pay' but some were never replaced.
E1PZ-10848-A .. Hard Plastic Cluster Back ~ Use with Oil & Amp GAUGES / Obsolete
Applications: 1975/79 F100/350 / 1975/91 Econoline / 1978/79 Bronco.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 547 = 800-476-9653.
E1PZ-10848-B .. Hard Plastic Cluster Back ~ Use with Oil & Amp WARNING LAMPS / Obsolete
Applications: 1975/79 F100/350 / 1975/86 Econoline / 1978/79 Bronco.
CARPENTER has 96.
Note: Same printed circuit boards:
With Oil & Amp GAUGES: 1976/79 F100/350, 1976/91 Econoline, 1978/79 Bronco.
With Oil & Amp WARNING LAMPS: 1976/78 F100/350/Bronco/Econoline // With Oil & Amp WARNING LAMPS: 1979 F100/350/Bronco & 1979/86 Econoline.
Last edited by NumberDummy; May 5, 2012 at 08:10 AM. Reason: This is...at least...the 200th time I've typed this same info here on FTE!
Old May 5, 2012 | 08:34 PM
highguy2012
wicked, thanks, I will order and see how it goes!!
bamboo321
Feb 1, 2013 06:20 PM
jjurva
Nov 14, 2012 01:24 PM
78'Ranger
Apr 5, 2008 05:47 PM
catbird7
Electrical Systems/Wiring
Mar 29, 2006 03:59 PM
77traded
Mar 27, 2005 06:57 PM
