dash lights not working
Old Jan 31, 2013 | 09:52 PM
bamboo321's Avatar
bamboo321
hello so my dash lights r not working when i turn on my lights so i was wondering how to fix them
Old Feb 1, 2013 | 09:03 AM
fmc400's Avatar
fmc400
MSEE
If you want to receive thoughtful advice here, please do not construct your posts like a text message.
First question: do none of your dash lights work, or just some? If only select ones don't work (for example, the heater controls light up, but not the instrument cluster), then specify which lights are not working. If none of them work, turn on the headlights (such that the dash lights would be on if they worked) and rotate the headlight **** all the way counterclockwise, either until it clicks into place (turning on the dome light) or just before that point. Check the voltage on BOTH sides of the dash illumination fuse, and report your results.
Old Feb 1, 2013 | 06:01 PM
bamboo321's Avatar
bamboo321
none of my dash lights are working
Old Feb 1, 2013 | 06:20 PM
fmc400's Avatar
fmc400
MSEE
...okay, then I've already listed out what your next step needs to be.
troverman
Aug 21, 2016 10:32 PM
ASoCalCowBoy
Nov 12, 2006 10:13 PM
catbird7
Electrical Systems/Wiring
Mar 29, 2006 03:59 PM
77traded
Mar 27, 2005 06:57 PM
August42
Oct 6, 2004 10:32 AM
