Dash Lights not working
Old Oct 21, 2011 | 12:03 AM
jjurva's Avatar
jjurva
1976 f20 I checked all the fuses in the fuse panel and they were all good. Why aren't my dash lights working?
Old Oct 21, 2011 | 06:02 AM
i-w's Avatar
i-w
have you replaced any bulbs or tested the bulbs themself?
Old Oct 21, 2011 | 07:25 AM
nlareau's Avatar
nlareau
Here's a shot in the dark (pun intended). My cluster was oxidized. Pull it and look at the copper on the printed circuit. Dark brown isn't real good. Get light sandpaper and LIGHTLY sand the contact until the copper brightens up a little. It doesn't need to be shiny, just clean. then look at the tabs on the bulb sockets. Clean them and bend them a little to make firm contact.
Old Oct 22, 2011 | 07:55 AM
fmc400's Avatar
fmc400
MSEE
In addition to the excellent advice posted above, the headlight switch can also be suspect. The dash lights are powered through a rheostat in the headlight switch; if this builds up corrosion (which is common), the current to the dash lights can get cut off. Save this step for last.
Old Oct 22, 2011 | 08:24 AM
MiddleNameMUD's Avatar
MiddleNameMUD
If your gear select light on the column and the lights for your temp. Control work, it won't be the switch...
Old Oct 22, 2011 | 10:40 AM
john81chevy's Avatar
john81chevy
no lights
I have a 1973 f100 which turned out to be the switch. I had a couple of old ones around and all gave me headlights, one with dash lights but no dome, and the other gave me a dome light but nothing in the dash. I tried yet another old switch I had and everything worked.
Old Oct 23, 2011 | 10:34 PM
jjurva's Avatar
jjurva
Thanks for all the help I'll try all that and see if i can get em working.
Old Nov 14, 2012 | 01:24 PM
denhills's Avatar
denhills
I have the same problem with a newly purchased 1976 F-150. No dash lights. checked all fuses and cleaned the fuse posts. Now I have light to the radio but nothing else. How do I get the cluster out to check it?
stm76
Nov 27, 2018 11:30 PM
Zachthemoo2
Sep 18, 2014 11:34 PM
77traded
Mar 27, 2005 06:57 PM
CoachRobb
Electrical Systems/Wiring
Apr 11, 2004 06:20 PM
CoachRobb
Mar 28, 2004 04:33 PM
