Hole in transmission case?
I have the same hole - years ago I had a solenoid replaced for the forward to reverse shifting issue. It was done under warranty at a large Ford dealership. I questioned the hole a few days after I got the truck back, and they told me it was necessary for the repair and that's how Ford want's them to do it....
After driving, i smelled something horrible burning. When I get home, I get on my creeper and roll under to look for anything suspicious, and I find this. It is not where the drain plug in the pan is, it's in front of that. I checked the temp when I was driving but it never got high. It would greatly appreciate any information, I really need my transmission to not explode on me right now, I have a lot of driving to do.
Here's a gallery where there are some pictures, Hopefully someone can tell me what is the problem. It looks like there were threads, and some are left, but it looks like most are gone.
Photo Album - Imgur
Photo Album - Imgur
What all could cause the bang and lack of power, there's no smoke engine sounds fine, transmission still shifting just lacking power to get past 60 km h after I reach 60 km h the revs go from 2000 and 3000 and bounce back and forth
There's no threads on the same size hole in my truck
The following users liked this post:
This is the 2nd 5R110W I have seen with a hole in that location.
The first was someone posting asking about it. It was done with a
chisel by the looks of things on that one.
On the Transmission I had die on me there is no hole and the same
for the one in the truck now No hole.
6.0L Tech Folder
6.0L Tech Folder
The hole is put there by a tech. It can be for 2 reasons. One is to aid in ensuring the torque converter snub is aligned with the engine crank and flush with the flexplate instead of just drawing it in tight with the nuts and hoping it's in all the way.
Second you can check for a rear main leak.
I got one in mine too. I drive a 2003 f250sd XL 5.4l and I too have a whole in my transmission, today I hot out if the truck after shutting it off and sitting there for a minute I saw smoke, there was transmission fluids dripping out from hole and dripping on hot exaust=smoke.
is ther a seal missing???
Rollerz70
09-30-2018 09:11 PM
crazytwo
04-07-2015 10:09 PM
devongoble
1997-2006 Expedition & Navigator
02-23-2015 09:25 AM
