thin paint
Old Mar 2, 2012 | 10:13 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by CruiserClass
You guys make me scared to buy anything new. Seems like a roulette wheel if you get something that will last or not...
Tell me about it. And if you get a nitemare like my 08 Expy you'll always be wondering when the paint will flake/bubble/blister.
I had a real hard time convincing myself to buy another new Ford after having 3 brand new with paint issue. So this time I leased. It's cheaper than buying, and I can simply walk away from the vehicle if it decides to rust out on me
Btw, if your vehicle does start rusting, Ford will likely blame you for not washing it
/rant
Old Mar 2, 2012 | 02:24 PM
sam71sportcustom's Avatar
sam71sportcustom
went to the dealer today and by time i got home they called and ford said they will fix it
Old Mar 2, 2012 | 03:01 PM
JeffHann74's Avatar
JeffHann74
I too have thin/light paint on my hood hinges, firewall and on the bottom of the doors. I also have bubbles in the drainage channels on the roof. I picked mine up last Sat... Feb 25.
Old Mar 2, 2012 | 03:50 PM
Ford8502's Avatar
Ford8502
Yours was built in KC wasn't it?
The hood hinges and firewall would not bother me. That seems more typical of past trucks I've had. But the door bottoms would cause a trip to the dealer! Although I had a Ranger years ago with similar poor paint on the door bottoms and I never worried about it. Had it 10 years and it was fine other than the looks of it. I think most of the protection comes from the metal coating and primer anyway. The top coat of paint is primarily for looks.
Old Mar 2, 2012 | 06:23 PM
efx4's Avatar
efx4
As an automotive refinisher for 25 years, I see that most car companies have been doing this for many years. Anywhere that is hidden or not exposed directly to weather often doesn't get full paint coverage, and the Japanese is a big offender of this. However, this doesn't mean that this is an issue, because everything is dipped in electrically charged primer and and the metal in the lower areas of the vehicle has some galvanization to it, and not to mention mastic bonding materials to doors and between many of the panels. If anyone has noticed, the 2004 on up F-150's don't have the rust issues the earlier models has because of these practices used now. The thin coverage in the hidden areas is not just a Ford thing.
Old Mar 2, 2012 | 06:59 PM
JeffHann74's Avatar
JeffHann74
Yes, mine was built in Kansas City.
efx4... so, all the auto makers have adopted the practice of half *** painting?
Old Mar 2, 2012 | 07:11 PM
cgartly's Avatar
cgartly
Bubble's in the drainage channels on the roof would bother me. Wasn't there another member on this forum that had that issue and decided to force the issue and replace his truck?
Old Mar 3, 2012 | 08:19 AM
gillis9's Avatar
gillis9
Bubble's
I will receive my F 150 FX4 2012 this week I'm ready for vibration tests ;after reading your comments I think I'll do a thorough inspection of the painting.
Thank You
Gilles
Aeronaut
Nov 29, 2020 11:59 AM
FORDFAN70
Paint & Bodywork
Aug 20, 2010 06:51 AM
SouthBay420
Appearance & Dress-Up
Aug 5, 2003 01:32 PM
bigjon
Oct 5, 2002 11:02 PM
Bronco894x4
1978 - 1996 Big Bronco
May 27, 2002 05:52 PM
