Well........it happened.
Old Sep 16, 2012 | 08:33 AM
  #2641
Jigger2020's Avatar
Jigger2020
He did post a link up there Gavin^^^^^^^#2636
Wow thats a BIG tank Gavin
Old Sep 16, 2012 | 08:38 AM
  #2642
Tomahawk's Avatar
Tomahawk
Doh! Thanks Gerry. Need more coffee.
Old Sep 16, 2012 | 08:42 AM
  #2643
Jigger2020's Avatar
Jigger2020
No problem Gavin, take yer time, I really like the trax-II set up, well worth the cost
Old Sep 16, 2012 | 09:23 AM
  #2644
ruschejj's Avatar
ruschejj
The trax system relies on a sending unit in the aux tank and also ties into the circuit for the factory sending unit. Have to locate the signal wires in the frame rail and splice into them. It was easy, detailed instructions for transfer flow were very good, took me 2 hours to install, including wiring up the power and running signal lines to the dash. I used an upfitter rather than using a fuse tap, much easier.
Retro fitting this system to a different tank would be tough, has to have a sending unit, proper resistance ratings, and it's own fuel pump for the transfer.
Old Sep 16, 2012 | 09:45 AM
  #2645
Jigger2020's Avatar
Jigger2020
Great info Joel & thats what the upfitters are for, we may as well use them
Old Sep 16, 2012 | 09:48 AM
  #2646
Tomahawk's Avatar
Tomahawk
RDS uses gravity flow and a check valve. I like the idea of having a fuel pump in the aux. tank that I can turn on and off. The other option is to add a NC valve to the gravity feed transfer line to control the flow.
I really would really like to have a gauge on the aux. tank too.
Old Sep 16, 2012 | 09:51 AM
  #2647
Jigger2020's Avatar
Jigger2020
Do they make a gauge for the Transfer Flow tanks
Old Sep 16, 2012 | 09:54 AM
  #2648
Jigger2020's Avatar
Jigger2020
I like the gravity flow system too, nice & simple
Old Sep 16, 2012 | 10:09 AM
  #2649
Tomahawk's Avatar
Tomahawk
FYI Guys,
Newegg Shellsocker deal at 4:00 pm PT.
It's gonna be $17.99 + free shipping.
Linky for deal. Check link after 4:00 PM PT, 5MT, 6CT, 7ET
Time to go play in the shop.
Old Sep 16, 2012 | 10:19 AM
  #2650
Jigger2020's Avatar
Jigger2020
I have a temp reader Gav, those things are handy
Old Sep 16, 2012 | 04:16 PM
  #2651
ruschejj's Avatar
ruschejj
Help!!!
I'm stranded in Ocala, fl. There's an FTE guy here, can't remember his handle. I need to reach him heh as two f350 an 08 and 12.
8649417345. This is important. Please help me. I need this man to reach me. He has been a friend, I just can't remember his name!
Old Sep 16, 2012 | 04:23 PM
  #2652
ruschejj's Avatar
ruschejj
Its gwcon. I sent him a message. Pound him with messages until he calls me!
Old Sep 16, 2012 | 04:48 PM
  #2653
Jigger2020's Avatar
Jigger2020
Good luck Joel, I'll PM him too...........does he owe you money, lol
Old Sep 16, 2012 | 06:10 PM
  #2654
Jigger2020's Avatar
Jigger2020
Joel he's lookin for you now, he replied to my PM
Old Sep 16, 2012 | 06:50 PM
  #2655
ruschejj's Avatar
ruschejj
Thanks gig. We're exchanging messages.
My engine died. All the coolant from the primary system is in the crankcase. The primary cooling system is completely drained. Oil level is half way up the dipstick cable. Secondary cooling system is intact, so it's not EGR related.
The starter won't turn the motor, it's pretty well seized.
121,828 or something like that. I have the extended warranty. I pray that the Ocala dealer is decent!
My fifth wheel cargo trailer is in the hotel parking lot and I can't get it myself for at least 8 days. I don't want to ask the hotel management to deal with it for over a week. I hope I can have it towed or that someone around here would be able just to take it home until I can round up a truck and get to it.
I have to work in clermont, jax, Hialeah and I have no down time in between those jobs. My father is on his way to me with his 150 and a small trailer I can load some gear in and survive the rest of the week. Luckily the big steel is no longer needed, used it yesterday up in Mississippi.
And wow, I've never lost a motor! Big loud rough mechanical clanking sounds.....outta nowhere.
