Assuming 3 speed manual column shift, look for it under hood where the shift linkage rods are. Not familiar with anything that new, but definatly a switch somewhere.
Bracket, D4TZ-15517-A w/ 3 spd manual w/ PS
Owen Ford Inc., Jarratt, VA has 3 (434) 535-8515
Wesley Obsolete Parts, Liberty, KS has 1 (606) 787-5293
D4TZ-15517-B w 3 spd manual w/o PS
I couldn't locate any
Switch, C9TZ-15520-F
Green Sales, Cincinnati, OH has 34 (800) 543-4459
Dennis Carpenter, Concord, NC has 3898 (!) (704) 786-8139
Wesley Obsolete Parts has 4
Bell-McCall Co, Hamilton, MT has 2 (406) 363-2011
There are other switches available. If you want more names let me know.
Just a little heads up, the last list on the switch was $96.29 (!!)
National Parts Depot sells the "early Bronco" switch that is NOT the exact replacement dispite the correct picture in the catalog. It is a more rugged switch but does not mate with the factory plug connector. You will need to rig something to go between the switches screw on wire lug connectors and the factory plug.
The bracket is simple in design and just "radiator hose clamps" onto the column.
Their switch is about a third of the "correct" switch so if you are not interested in originality that STANDARD autoparts switch may work for you.
Reason: Left something out
thanks for all the help but i now have another problem the connector that is under the tailgate for all the rear lights is there a diagram for how this hooks up?
