1960 backup lights?
Old Mar 9, 2007 | 08:56 AM
oldsenile's Avatar
oldsenile
1960 backup lights?
I have a box that's suppose to be optional for 1960 f100 that has backup lights in it. Where would the switch for the lights be located? Thanks
Old Mar 9, 2007 | 09:23 AM
Randy Jack's Avatar
Randy Jack
Backup lights are typically switched on by the gear shift selector position being in reverse. Everytime the selector passes thru reverse, the backup lights flash. staying in reverse leaves the backup lights on. We'd have to know what tranny you have to give more specifics, but the basic idea is the same on all trannies.
Of course, you could easily put a manual switch on/under the dash to just flip them on, but whoever remembers to do that?
Old Mar 9, 2007 | 09:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What is the part number on the box?
Old Mar 10, 2007 | 07:41 AM
brewster1's Avatar
brewster1
I have backup lights on my 60 3-speed. I used a switch from a 55 Ford manual shift passenger car that bolts on the steering column at the gear shift levers. When put in reverse and the lever on the steering column comes up, it pushes the switch. I think the trucks used this same type switch. The auto trans is a little different as it has the neutral start wires incorporated into the switch. I am running mid-sixties barrell tail lights with the back up lens in upper half of the tail light.
jt
Old Mar 11, 2007 | 07:01 PM
oldsenile's Avatar
oldsenile
Where would I find that information? I'm thinking there should be a switch on the 3 speed std. trans. I don't know if thats right or some where under dash by linkage.
