Gearbox question/problem
Old Feb 23, 2012 | 08:15 AM
JKessler00's Avatar
JKessler00
I'm in the middle of my restoration and just got to the gearbox. Against others' recommendations, I have decided to rebuilt/reseal it. I took the valve body and piston out as one assembly, therefore the ball bearings didn't come out and I'm in good shape. The problem is the needle bearings for the worm shaft. They looked good, but fell apart on me. No one lists these bearings, so I'm wondering if I already have an upgraded/Redhead steering box? These needle bearings are probably two inches long on each end.
I have a '77 F-250 4x4 and I think I read somewhere that these gearboxes didn't have needle bearings? I need to try and figure out what I have and how to get the bearings. Help!
Old Feb 23, 2012 | 08:22 AM
mikeo0o0o0's Avatar
mikeo0o0o0
It sounds like you do have a Red Head, if not, someone else has done the upgrade. These boxes did not come with needle bearings on the pitman shaft.
As far as replacing the bearings, any good bearing supply house (Motion Industries, etc.) should be able to match up what you have. If not, you might try contacting Red Head and see if they can help.
Old Feb 23, 2012 | 10:31 AM
mark a.'s Avatar
mark a.
Use auto trans assembly paste or Vaseline to hold the needles together, greese won't dissolve.
trevorrules
Jul 23, 2013 05:22 PM
danger-ranger93
Apr 19, 2011 09:02 PM
I6power
Garage & Workshop
Feb 25, 2011 02:26 PM
Raider50
Aug 24, 2009 02:17 PM
aRKToS
Apr 30, 2009 07:06 PM
