Sponsored by: Auxito
92 ford bronco please help
Old Feb 21, 2012 | 08:51 PM
cmann7254's Avatar
cmann7254
Angry 92 ford bronco please help
Had to change rotor today took everything apart and put back together 7x. I cannot get the hub cap to go all the way on. There is about a 1/4" gap. Looked at other side and axle iis pushed out greater than the side i am changing. I have pulled the axle out as far as i can get it and there is still a gap. Please help me very frustrated.
Old Feb 21, 2012 | 09:19 PM
Longdistancetrucker's Avatar
Longdistancetrucker
Does it line up correctly? I can't visualize what it is your talking about?
Old Feb 21, 2012 | 09:24 PM
critterf1's Avatar
critterf1
He's got me lost, too.
Old Feb 21, 2012 | 09:28 PM
cmann7254's Avatar
cmann7254
I put the gears back in lockin nut washer etc then when i go to slide body assembly on it goes in but i can see old markings and its about 1/4inch out. I took the passenger side off and the axle is sticking out about a quarter inch more than the drivers side. I tried pulling axle out and it pulledbut still stops short. One thought was my jack location since its split axle but i lowered the jacm and axle didnt move. It is automatic 4wd.
Old Feb 21, 2012 | 09:38 PM
Longdistancetrucker
so you need to move in the entire wheel hub?
Old Feb 21, 2012 | 10:18 PM
cmann7254's Avatar
cmann7254
I guess maybe I dont know why would the axle be short on one side
Old Feb 21, 2012 | 10:28 PM
Longdistancetrucker
I'm still a bit lost.
As of right now it only sounds like you misaligned the vehicle, and in that case just get an alignment and you should be set.
any other member have ideas what may be wrong, this is starting to interest me.....
Old Feb 21, 2012 | 10:41 PM
cmann7254's Avatar
cmann7254
Im not sure all of my friends that have knowledge are lost. Would you drive a big truck if you a gap there sounds like id just ruin stuff but its tempting cause it might be fine. Mind you I live in Hawaii lots of hills and.curves dont wanna wreck
Old Feb 21, 2012 | 10:55 PM
Bluegrass 7's Avatar
Bluegrass 7
Start over again.
Are you talking about the front or the rear.
A hub is only on the front.
Is it 4 wheel drive?
If you replaced bearings likely the new bearings are not fully seated.
Give some clairity to what your doing.
We don't have crystal ***** to see with.
Old Feb 21, 2012 | 11:26 PM
cmann7254's Avatar
cmann7254
Its the front drivers side. It is automatic 4wd. The outer bearing fell out when I took hub off. I placed it back in and tightened nut. Im sorry im only an amatuer. Is there something I needed to do to bearing. Appreciate the help.
bentmetal
Escape & Escape Hybrid
Aug 14, 2012 12:27 PM
lafermedavid
17
Jul 28, 2011 08:55 PM
afinepoint
Sep 26, 2006 08:40 AM
429crossbolt
1983 - 2012 Ranger & B-Series
Mar 18, 2006 05:25 PM
lowcountry
Sep 25, 2005 08:28 AM
