Rev's drop...Is this normal.
Old Feb 21, 2012 | 06:54 AM
hookedondiesel's Avatar
hookedondiesel
1996 powerstroke 7.3.
At idle in park, it revs around 5 or 600.When I bring the rpm up to about a 1000 and hold it there, it will drop down to about 600 on its own. Same if I bring it up to 1500rpm's.
Is there something that keeps it from staying at a higher rpm in park.
Old Feb 21, 2012 | 08:57 AM
Talyn's Avatar
Talyn
Tps could be going bad.
Im stumped otherwise.
Old Feb 21, 2012 | 09:21 AM
fordpride's Avatar
fordpride
ICP ? Unplug the ICP and see if it changes
Old Feb 21, 2012 | 10:40 PM
oldbird1965's Avatar
oldbird1965
Talyn's probably right but its worth a try on unplugging the ICP.
Old Feb 22, 2012 | 04:15 AM
hookedondiesel
Ok, thanks guys, I'm gonna check the tps, mines a 96, and it looks like there's 2 sensors on the pedal.
It's not on the road yet, doing a 2x2 to 4x4 swap and noticed this the other day day.
I've read where some say the whole pedal assembly has to be replaced
and some say they have just taken apart the senor and cleaned it with contact cleaner and it fixed the problem.
I'm pretty handy with electronics, so when I get a chance, I'll take a closer look at it.
If that doesn't work, I'll try pulling the ICP, I hear their a biotch to get at.
Workin outside in the cold her on this one.
I'll let you know what gives if I get this fixed.
Never noticed this when I bought it, idles great but when you bring up the rev to about 1000 or 1200 and hold it, it drops about 300 rpms on it's own after about 2 seconds. Thanks for the tips.
Old Feb 22, 2012 | 09:13 AM
oldbird1965
Before you take it apart just spray it with cleaner, that works most of the time. IIRC, its a 9/16 wrench to get the ICP out and some guys will grind down the wrench to make it fit under there.
Old Feb 22, 2012 | 03:47 PM
hookedondiesel
Thanks for the tip, OB.
Strangest thing, I'm in the process of changing out the PSOM, got er all hooked up.
Let it run for a bit and thought I'd give the idle trouble a shot.
Brought it up to to 1200 rpm's, and it held there.
Did the same at 1500 and it still held.
Didn't do nothing else to the truck, could the psom have something to do with this.
I'll check it again tomorrow, and see what happens. Strange, very strange.
Old Feb 22, 2012 | 08:26 PM
oldbird1965
You changed out the Odometer Module? Never done that, is it hard? Is it the whole speedo? I hope it continues to work right.
Old Feb 23, 2012 | 04:15 AM
hookedondiesel
Yep, no,, it's not hard at all.
There's 7 screws that hold the whole unit in. They each have their own unit inside.
They just "clip in", so all you have to do is "pry" them out.
Pry up and out, the "gas" unit first, it hold the "speedo" unit in. The speedo unit just sit"s there and just comes out as a whole unit. The hardest part is removing the the steering wheel "covers" that surround the gear shift and key section so you can "unhook" the cable for the gear shift display.
Gas and diesel psom's are identical, same part number.
Ya, I hope so too, find this funny that this would affect my rev problem, but time will tell.
EDIT: the steering wheel surround covers don't need to be removed for this.
I had to take mine off for another reason.
Old Mar 19, 2012 | 04:25 AM
hookedondiesel
Another heads up on this issue,....
I was swapping out the rear diff, so the vss was disconnected.
I figured I'd start er up to keep it charged.
When i did, i noticed the "ABS" light was on, normal, I figured, since I unplugged the vss.
But I figured I'd try the "idle" issue again, just to see....
So I brought it up to about 1000 or 1200 rpm's, and held it there.
Guess what, the revs would go down to about 600 and back up to 1000, steadily,
up and down, with-out me moving the pedal.
After re-installing the vss, everything was back to normal, strange.
So my guess is, the psom and vss, have something to do with your idling issues.
Just thought I'd mention it, in case someone else had idling issue's that they couldn't resolve.
andysam
Apr 29, 2014 08:21 PM
CA-F250
6.7L Power Stroke Diesel
Nov 18, 2012 07:22 PM
someday
Jan 28, 2008 10:00 AM
munrow
Jun 9, 2005 08:19 AM
ASE
Sep 19, 2004 08:19 PM
