AE connectivity issue
Old Mar 19, 2012 | 09:50 AM
rat49f6's Avatar
rat49f6
I'm working on a 1997 F-Super Duty that will start just fine while cold but no start cold
New uvch and gaskets
New glow plugs
Imjectors re o-ringed
New ford grey cps
New ford ipr
Clean icp
So I hook up ae and it connects and scans all the sensors, according to the screen, but when I go into live tuning and pull up values they are all 0.0
When looking at the connector there are pins in the 2,4,5,10,13,16 locations
According to my research the pins are as follows
2 is data
5 is ground
10 is data
16 is power
I believe 4 is signal ground and I show 12.3 volts in pin 16 using both 4 and 5 as ground
What is pin 13? Am I right about pin 4?
How can I test for data coming across the two data pins?
Old Mar 19, 2012 | 10:20 AM
Hussler's Avatar
Hussler
This is what I show,
2 ... is aux power in
4 ... is ground
5 ... is ground
10 .. is data
13 .. is data
16 .. is power
On OBS trucks you need to set up the AE different. I believe you need to select non-OBDII for it to work. I don't have AE but that is what I've heard on this site.
Old Mar 19, 2012 | 10:26 AM
rat49f6's Avatar
rat49f6
Thx
Ae is set up for the truck ...it runs flawlessly on 2 other 97 7.3's
Old Mar 19, 2012 | 10:30 AM
DIYMechanic's Avatar
DIYMechanic
Is the F-super duty flashed with an OBDII compliant code? It wouldn't have been required since it is not a passenger rated vehicle (heavier GVWR). I don't know that this is the issue, but it seems like a valid question to me.
Old Mar 19, 2012 | 10:40 AM
rat49f6's Avatar
rat49f6
I was under the impression that none of the obs diesel trucks were required to be obd-II compliant
frustrated mechanic
2004 - 2008 F150
Jun 5, 2015 09:45 PM
bbender85
Oct 8, 2013 05:10 PM
surfpunk
Jan 22, 2012 07:31 PM
77300i6
1983 - 2012 Ranger & B-Series
Oct 15, 2007 08:55 AM
