just wondering what the stock automatic transmission is in a 95 f150 4x4 i was told the one i have in it now is a 4r70w and they had to look up parts for it on a 97 f150 any help would be nice
Look on the driver side door jamb- there should be a plate stamped with different information about your truck. The original transmission type should be listed.
If the 97 has the E4OD (which I believe it is more likely), I would stay away from it. It will work, but the E4OD's are garbage! Electronically modulated transmission that have a high failure rate.. That 4r70w is a very good transmission.. If you can get it overhauled, you will save yourself a ton of money in the long run!
Im not sure if the transmission is bad yet I just replaced the front clip on my truck while I was doing that it sat for about a month and now its not shifting right and there is plenty of fluid in it so I was looking on ocala4sale and found a 4r70w for $250 the guy said its out of a 97
The E4OD is a good transmission IF it has the upgrades done to it that started in 1993 or 1994. If it's been rebuilt since then it should be a solid and reliable transmission. All you have to do is keep the fluid clean and take care of any electronic issues (sensors, etc.) that crop up while using it.
All of which is moot, of course, because a 1997 F-150 never came with an E4OD. They are all 4R70W. Also, a 1997 F-150 has a modular bolt pattern which is completely different from the 300/302/351w pattern that your 95 has.
So whoever said that the trans will work fine is mistaken.
