Chip install question
Old Feb 20, 2012 | 04:23 PM
Diesel cat's Avatar
Diesel cat
Well this isn't a ordinary question. Just wondering when installing the switch on the dash what it's the best way to remove the black dash cover. Does it just snap in. I have a obs.
Old Feb 20, 2012 | 04:38 PM
1dieselman's Avatar
1dieselman
There are screws behind the trim on each side of the column. Pop the trim pieces and headlight switch **** using a small screwdriver in the notch in the backside of it. Remove the screws that where behind the trim then the bezel should pop off.
Old Feb 20, 2012 | 04:40 PM
Diesel cat's Avatar
Diesel cat
Thanks a bunch
Old Feb 20, 2012 | 04:45 PM
stainlessstroker95's Avatar
stainlessstroker95
Pop the trim off with a screw driver and there is a couple torx screws behind them. Pull out your headlight switch then turn to the slot and use a small flat head screw driver to push on the little clip and pull **** out at the same time. With a little wiggling the black panal should pop out of the clips.
Old Feb 20, 2012 | 04:47 PM
stainlessstroker95
Man im a slow typer.
blue924.9
Mar 9, 2014 07:39 PM
wicat3
Dec 8, 2011 09:35 AM
Dan Robertson
1997 - 2003 F150
Dec 5, 2009 12:08 PM
murrhee
Oct 14, 2009 04:45 PM
DrBones
Bronco II
Mar 21, 2002 09:00 AM
