CEL on / off
Old Mar 25, 2012 | 12:05 PM
  #46
Leemakesmepee's Avatar
Leemakesmepee
Originally Posted by fordpride
Have you checked the HPOP oil level?
I have not check the hpop oil level. To do that you take that bolt out of the resivor. And do you just eye it to see if its at the top?
The engines oil was full and had no leaks.
Old Mar 25, 2012 | 12:08 PM
  #47
fordpride's Avatar
fordpride
Yup just take the plug out the top. The oil should be about a1/2-3/4" from the top.
I'd also put a gauge on the LPOP to see if for some reason it took a dump on you
Old Mar 25, 2012 | 12:12 PM
  #48
Leemakesmepee
If it isn't at those levels. Should I just add regular oil?
As for the lpop where is it located on the motor, and what type of gauge should I put on it?
Old Mar 25, 2012 | 12:23 PM
  #49
fordpride's Avatar
fordpride
If lower than that just fill it with 15-40 diesel oil
Get a 0-60psi oil pressure gauge from autozone and put it in the top of the HPOP reservoir.
When cranking does the oil pressure gauge on the dash move?
Old Mar 25, 2012 | 12:27 PM
  #50
Leemakesmepee
It took a really long time of cranking to move the gauge. It was pretty cold if that could possibly have something to do with it.
Old Mar 26, 2012 | 02:52 PM
  #51
mattman347's Avatar
mattman347
I did not see, but are you getting a wait to start light?
Old Mar 26, 2012 | 02:55 PM
  #52
Leemakesmepee
Yes, wts turns on every time we go to start it.
Old Mar 26, 2012 | 03:02 PM
  #53
mattman347's Avatar
mattman347
Just for fun, pull the fuel bowl heater plug on the side of the fuel bowl. When you are cranking are you reading any ICP pressure?
Luminous
Aug 11, 2017 03:24 PM
Diesel 724
Feb 17, 2014 06:04 PM
iateatoad
13
Dec 8, 2012 10:35 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
cathlabdog
Oct 25, 2006 07:20 PM
