Stalled while under throttle,n o start
Old Feb 23, 2012 | 03:21 AM
  #31
npccpartsman's Avatar
npccpartsman
Originally Posted by going up 2!
Had some time today to pull valve covers and inspect dummy plugs and upper part of stand pipe,lower tube stuck in there. All orings so far looked ok but had to close up shop for the night. After work I'll remove lower standpipe piece and repace all parts. BTW before I tore down I had a chance to scan and only thing it read was low oil pressure. It's only reading 40 psi of HPO! Gonna grab the socket and replace IPR. What's the chance it's the pump? Oh,and any tricks to getting lower standpipe out w/o removing rail?
Thanks again.
Getting the standpipe without removing the rail depends on which side. I've used "needle nose" vise grips and even driven screwdrivers into them because that's all I had. You'll have to remove the rail on the passenger side to get the complete standpipe in and out because of the heater box.
Old Feb 23, 2012 | 06:18 AM
  #32
Curt's05's Avatar
Curt's05
Wiser by FTE
Sorry for the no-start, does anyboy know if the stc kit # 4C3Z-9B246-F i have comes with dummy plugs & stand pipes?
Old Feb 23, 2012 | 07:08 AM
  #33
bismic's Avatar
bismic
The kit should contain:
* 1 Support Bracket
* 1 Hydraulic Pump Seal Kit
* 1 Branch Tube Adapter - Male
* 1 HPOP Adapter Fitting - Female
* 2 M6 X 35 mm Branch Tube Bolts
* 2 M8 X 60 mm Pump Bolts
* 1 M8 X 45 mm Pump Bolt
Old Feb 23, 2012 | 04:37 PM
  #34
2006powerstroke90's Avatar
2006powerstroke90
I do not believe the STC kit comes with the standpipes and dummy plugs...im almost positive.
Old Feb 23, 2012 | 09:06 PM
  #35
going up 2!'s Avatar
going up 2!
STC came with fitting and screen,orings for IPR. Standpipes and dummy plugs came as kit. After starting w/ STC,dummy plugs,and stand pipes the IPR itself was the issue. Always the easiest think to get to last!!! Now at least I have a little knowledge of HPO leaks on our trusty ol' 6 leakers. Thanks to all!!! Adam
Old Feb 23, 2012 | 09:08 PM
  #36
going up 2!
She Runs!!!
fordman67
116
Jun 9, 2016 08:23 AM
Blakegregory
Sep 18, 2014 04:23 PM
Deerslayinrenek
Apr 12, 2011 11:15 PM
alanc77
15
Jul 2, 2007 07:02 AM
ssbuck1
Apr 28, 2005 10:39 PM
