oil leak
Old Apr 28, 2005 | 11:32 AM
ssbuck1's Avatar
ssbuck1
oil leak
I recently had my motor rebuilt in my 86 Bronco, It leaks oil after it has been shut off after a drive. It does not leak every time only a couple days a week, I have noticed that my oil pressure runs high sometimes. Any ideas on what could cause this?
Old Apr 28, 2005 | 11:42 AM
Boss50's Avatar
Boss50
Maybe when your oil pressure gets too high it blows it past the seals. Just an idear.
Old Apr 28, 2005 | 12:23 PM
ssbuck1's Avatar
ssbuck1
thanks for the reply, any idea why the oil pressure would change
Old Apr 28, 2005 | 10:39 PM
85F_150driver's Avatar
85F_150driver
are you watchign oil pressure on the dash gauge or on a mechanical one? if on the stock in dash one it could be a bad sender, could also be your oil leak location. I have a mechanical gauge and i can watch the pressure go from 60psi at cold idle to about 20psi at opperating temp. When i rev i it goes back up to 60. I would recomend getting a set of real gauges and hookin them up to keep a eye on things.
