6.2L V8 Discuss the 6.2L V8
6.2L mpg update?
Old Jul 30, 2020 | 01:17 PM
  #526
Terry Lewis's Avatar
Terry Lewis
Originally Posted by landscapeguy
that is low, you must have bad driving habits for mpgs. I get 14-16 empty and 9 towing. And if it's all 55-60 mph roads I get around 16.5-17
you couldnt push mine and get those MPG, however mine also had a 5th wheel and a tool box and back seat converted to sleeper. empty weight my truck was at 8500.
I got rid of it the otherday and got a new 250 diesel
Old Jul 30, 2020 | 01:36 PM
  #527
ncred02's Avatar
ncred02
12...all day. Loaded , empty, raining, snow...dont matter
Old Aug 5, 2020 | 07:06 PM
  #528
wdbates's Avatar
wdbates
mog
2016 CC 4X4 SB 373s 60000 plus miles totally stock
15-15.4 MPG 2000 rpm just short of 80mph freeway on cruise
12-13 give or take city travels
towing travel trailer 7000 lbs with 900 lbs tug weight trailer 8.4-9.2 from LA CA to Dallas tx
pulling a 20 foot enclosed car hauler full of funiture ,LA CA to St george UT 8.2mpg
all towing speed 65mph
Old Oct 8, 2020 | 08:10 PM
  #529
kry226's Avatar
kry226
Finally got a 600 mile tank!
Yesterday, I drove home from the Texas Panhandle and fueled up at the first Love's I came to on the Oklahoma side of the state line on I-40. I drove to about 20 miles west of St. Louis before I had to fill up again. 87 octane, and I didn't baby it at all. Average speed per the dash was 76 mph. Not towing but had a couple hundred pounds in the bed, plus an ARE Z-Series top, and me. Standard 60/65 psi in the tires. Next tank was tracking equally well but made it home with still a half tank to go, and already over 300 miles driven on that tank.
I may never do it again, but I did it once.
Old Oct 9, 2020 | 12:55 AM
  #530
petwofan's Avatar
petwofan
600 Miles on 1 tank????
603 miles for 1 tank at 13.6 MPG?
You have a 40+ Gallon fuel tank?
Old Oct 9, 2020 | 04:30 AM
  #531
kry226's Avatar
kry226
Yes, the CCLBs have a 48 gal fuel tank. It's probably my favorite feature of the truck.
Old Oct 10, 2020 | 05:28 PM
  #532
petwofan's Avatar
petwofan
Got ya. Mine is a short bed so I have a smaller fuel cell.
Had me wondering
Old Oct 27, 2020 | 07:41 AM
  #533
smokewagun's Avatar
smokewagun
Originally Posted by DCP
People don't buy heavy duty trucks for their MPGs. The only thing I expect out of my 6.2L gasser is, longevity and relatively cheap cost of ownership.
And how many miles do you put on a year? Some of us who clock substantially more than 10k a year, but need to balance periodic towing/hauling heavier than a half ton will allow, but daily drive, DO find reason to watch mpg. The difference in mpg between the lowly 6.2L and the premium 7.3L $1700 upcharge mill means upwards of $1,500 to $2,000 a year in fuel alone for me. Anyone who says mpg and heavy duty shouldn’t be used in the same sentence can write me a check for $10,000 right now.
Old Oct 27, 2020 | 08:28 AM
  #534
windellmc's Avatar
windellmc
Are you saying the 7.3 is more or less efficient than the 6.2? I can tell you from experience with the 6.2 the 3.73 gears are a lot more efficient than the 4.30. It was 10% for me going from 3.73 CCSB to 4.30 CCLB.
I am sure Ford fleet customers care a lot about mileage too.
One idea I am toying with is getting an F150 with the heavy payload package as a sort of baby super duty. It should get mileage in the high teens and still have over 2000 lbs of payload.
Old Oct 27, 2020 | 12:08 PM
  #535
Ron94150's Avatar
Ron94150
I would have to respectfully disagree. This coming from someone who had a 6.2 3.73 stock tire truck, and went to 4.88's w/ 37's. I lost less than 1 mpg on my daily average. My dad also has a 6.2 4.30 truck that I've logged a lot of miles in. There is very little difference in the fuel economy. And maybe that's because there's lots of hills here and possibly flat where you live?
Old Oct 27, 2020 | 01:26 PM
  #536
tibadoe's Avatar
tibadoe
I just went past the 3 year mark last month. Don't drive much (6k) but I do still keep an eye on my mileage. So far still keeping up with each fill-up and logging every one into Fuelly. At 25 fill-ups the lifetime average is 13.6 mpg with the best being 14.4 mpg - all hand calculated. The guess-O-meter has been optimistic 92% of the time averaging about 2 mpg more than reality - with only two times (8%) being spot on.
Old Oct 27, 2020 | 10:20 PM
  #537
h20camper's Avatar
h20camper
With a fairly even mix of town and highway driving, here is my hand calculated MPGs (FillUp app). My IPC shows a lifetime average of 15.6 and max individual trip, ~800 miles, of 18.2. Both are 5% optimistic over the hand calculated numbers. This truck with 4.30s actually has a better lifetime MPG average than my almost identically equipped 3.73 truck. (See signature). Admittedly, I don’t tow but do haul on occassion.
Old Oct 28, 2020 | 03:16 PM
  #538
windellmc's Avatar
windellmc
It is relatively flat here and either truck would pull 6th gear all day long on the highway as long as a travel trailer was not attached. With the trailer the 4.30 truck would run a gear higher than the 3.73, and that was pretty much the only difference there. Either truck could spin the rear tires in first with the trailer attached.
Matt
Old Oct 28, 2020 | 10:11 PM
  #539
smokewagun's Avatar
smokewagun
I was saying the 7.3L gets worse mileage. I, too, have considered going to a HDPP F-150, but I don’t like stripped trucks. The 2021 changes that... a bit, but regardless, if the trailer is pushing 8k, I don’t care to pull it with a 1/2 ton. That’s me. I’ve pulled a lot of trailers in 25+ years, and most with Super Duties. I’m just not interest in a $10k diesel adder when I’m trading every 3-ish years.
Old Nov 19, 2020 | 12:57 PM
  #540
gunit1400's Avatar
gunit1400
A question that begs to be asked is did you change your truck with forscan or at the dealer to account for the different gears or tire size? And the post that you replied to was comparing factory options, not re-geared trucks with larger tires. In the pursuit of fairness, that has to be considered.
