Another oil cooler thread-deltas really matter with egr delete?
Yup-starting a new oil cooler thread.
I was doing some research on ipr's "upgraded" oil cooler-which I said it WILL increase your deltas to 25-30 degree spread but a 220-230 degree eot is fine.
Same thread also said that the main reason ford put the 15 degree spread in the first place was because that was when the cooler showed signs of clogging and thus limiting the amount of coolant flowing through the egr...causing egr failure.
Now-for those of us (including me) who have the egr deleted-do these large oil spreads mean we have to replace the oil cooler still?
What other ill effect (besides killing the egr-which is deleted) does running with a clogged oil cooler have? (Besides if its clogged enough to reach eot of 253 degrees to defuel the engine)
And to add-my current ect is 190-192 and eot was 225-235
I understand its not working as efficiently as it could be and should be replaced-but is it as big of a deal as every one makes it out to be?
I mean-its not a cheap repair, and my current game plan is to get an ipr coolant filter, run it for a month or two then pay someone to replace my oil cooler with a new ford oem one. But if its something that can be driven on for a while with no ill effect, then I don't have to rush to replace it and dish out over $1k to get it done.
Engine oil is rated at much higher temps then 230, no egr to crack and make coolant puke, what else would fail or break due to a clogged oil cooler? That's my question.
Like I said-I have full intentions on getting it replaced-just curious why everyone makes it out to be a huge deal when I don't see the danger in it. Hell most people without gauge have no idea anythings wrong and are running hotter then my oil temps.
I don't know the number, but there's a certain temperature at which plastic things in your engine (like the oil filter housing) start to melt, distributing melted plastic all through the oil system. That would be very bad. People change it before they get to this point if they know there's an issue with the oil cooler.
Again....I completely understand what happens when an oil cooler ruptures.
I DONT understand how one would rupture from a delta over 15 degree...
Sorry I'm not trying to be stubborn just trying to grasp how these deltas are that big of a deal without an egr (with an egr I completely understand-loss of coolant flow to egr causes overheat causes crackin leads to puking.)
Mattdoc-from what I've read that happens at 350+ degrees-
You miss read that one ,limp mode saves itself (or the driver) from self destruction, it may not break open right away but it will,and when it does it's a mess to clean out. Bearing are then in jeopardy of being damaged ect. Hey but it's your truck ,your money. I can only give good advise and suggest you catch it with early warnings
The heat-I don't think 230-240 or even 250 should cause an issue
Cooling system pressure-again not sure this would cause an issue unless there was substantially more pressure in your system then there should be.
Now crap in the system "sandblasting" the oil cooler down to make it thin and then rupturing-that makes sense!
Just trying to get more of an idea how these things fail and how much longer I can run it (I'd like to get a couple more months out of it to use the coolant filter to get all the junk out of my cooling system prior to a new oem oil cooler getting installed)
