Oil cooler imminent?
Old Apr 27, 2015 | 03:07 PM
Aune163rd's Avatar
Aune163rd
I'm up tip a 20 degree spread between the two. Is it a matter of time?
Old Apr 27, 2015 | 03:11 PM
nmclella's Avatar
nmclella
Ford states 15 degrees as the time to change the oil cooler.
If your EGR is deleted some argue that deltas no longer matter as much.
Old Apr 27, 2015 | 03:15 PM
69cj's Avatar
69cj
Under what conditions are you getting the 20 degree spread?
Old Apr 27, 2015 | 03:20 PM
Aune163rd's Avatar
Aune163rd
I'm getting it cruising through tuning hills in Montana. At WOT uphill the gaps close to 6 degrees.
Old Apr 27, 2015 | 03:22 PM
Aune163rd's Avatar
Aune163rd
EGR is still there. As far as I know it's a stock truck
Old Apr 27, 2015 | 03:36 PM
69cj's Avatar
69cj
For the spread to be valid the truck must be thoroughly warmed up, app. 15 miles highway driving, and then cruising between 60 and 65 mph with no load on flat ground. Climbing, cresting or descending hills will give you a bogus reading.
Old Apr 28, 2015 | 02:36 AM
Aune163rd's Avatar
Aune163rd
Still at 17-20. I'm doing the oil cooler tomOrrow
anassar11
Apr 5, 2012 01:46 PM
jl4407
Apr 3, 2012 03:29 AM
swampfire79
Feb 19, 2012 12:18 AM
chromedom
May 19, 2010 12:19 PM
