AAAAUGH. tires !!!
Old Feb 27, 2012 | 06:41 PM
  #31
hairyboxnoogle's Avatar
hairyboxnoogle
Don't mean to hijack but that is good to hear aune I hear they're capping 35s and 37s now so I need to look into it. And of course you can't really beat the price. How does their aggresive tread last on the hwy?
Old Feb 27, 2012 | 07:07 PM
  #32
greywynd's Avatar
greywynd
I ran retreads on the dually for a couple years. The day the retread let go, it cost me about $500 in lost income, plus I then had to buy 4 new tires anyway so I had a matched set on the duals. It also took out the mudflap and mounting bracket, and almost took off the filler neck under the bed.
I'll stick to buying new from now on.
BTW, the retread is still here, mounted up, and still holds pressure. It was simply the cap that let go.
Old Feb 27, 2012 | 07:15 PM
  #33
Aune163rd's Avatar
Aune163rd
Mine have lasted 55k miles that were on the Ranger, 29k when i sold the F-150, the 83, still on there, they are Mud Tires...with 45k....and the 84's are now on the 90...with 15k on them...they last and wear quite well...
Old Feb 27, 2012 | 09:05 PM
  #34
tecgod13's Avatar
tecgod13
Originally Posted by whiteboyslo
Do 265/75/16s fit on the OE wheels without any rubbing issues? The OEM is 235/85/16 on mine.
Mike
Depends on the size rim you have. My truck came stock with 235/85/16's and 6 inch wide steel rims. 265/75/16's are like an inch wider than 235's and should be run on 7 inch wide rims.
Luckily I found a guy selling 7 inch rims at the same time I got the tires so I used those and left the others tires mounted on the 6 inch rims as spares.
There shouldn't be any rubbing issues though as some trucks came with 265/75's.
Old Feb 27, 2012 | 10:08 PM
  #35
Aune163rd's Avatar
Aune163rd
It will not rub....i have the 265's on the 1990. However, I do know that 315/75/16's will rub, the 1990 came with that size.
Old Feb 27, 2012 | 10:17 PM
  #36
IDIDieselJohn's Avatar
IDIDieselJohn
Why swap back?
Mike
This truck will all be original once restored, so for that to be possible, need the factory stock size. Besides, I love tall skinny tires on 4x4 trucks
Now this thing has some character...with it's 235/85's nothing else.....
Chefsteele
17
Jan 27, 2014 06:15 PM
northernmoose
Offroad & 4x4
Sep 20, 2009 01:00 AM
gunpowder_250
Oct 14, 2008 03:07 PM
rgp
1983 - 2012 Ranger & B-Series
Nov 26, 2007 08:10 PM
cdherman
Apr 27, 2005 01:20 AM
