Idle problem and check engine codes?
Old Feb 12, 2012 | 09:27 PM
harryg753's Avatar
harryg753
Just recently my 89 f150 5.0 ive been noticing that the idle when cold has been really rough and almost like itll just rev up to like 1400 rpm and then jump down to 500-800rpm about 5 seconds after cold start up and hesitates alot once you hit the gas. Once its warm it isnt as bad. As this is happening, my check engine light just came on, and i checked the codes and i got a 23 and a 53 then 1 flash and 335 came up although i believe that was an old stored code. What do i do from here? People told me to just get a new TPS but i thought i can just adjust throttle? Any suggestions let me know thanks Harry.
Old Feb 13, 2012 | 08:11 AM
rla2005's Avatar
rla2005
Your truck is going to display 2 digit codes, not a mix of 2 and 3. Ford did not start using 3 digit codes until 1991. If Code 23 and 53 are accurate, that does indicate the TPS output voltage is not correct. Before tossing money and parts at it, invest in a cheap Digital Volt Meter (DVM). Those codes can also be caused by an open a circuit.
Old Feb 13, 2012 | 12:59 PM
docrw1's Avatar
docrw1
While your checking check the ect. Mine was bad and causing the same issue. Also check and clean idle control motor.
rj1983
Jan 5, 2018 05:59 AM
86stepsideF150
Oct 7, 2009 02:55 PM
ErnieX
Apr 3, 2007 06:50 AM
gunner9821
Feb 2, 2005 10:08 PM
sirkeithc
Jan 7, 2003 09:59 PM
