high idle
Old Jan 4, 2018 | 04:47 AM
rj1983's Avatar
rj1983
high idle
My truck has developed a high idle issue recently, however if I shut the truck off and restart it the truck will idle normally.
Has anyone else had an issue similar to this?
Old Jan 4, 2018 | 04:54 AM
rj1983's Avatar
rj1983
Forgot to mention, checked the codes and not getting anything on that front...
Old Jan 4, 2018 | 08:39 AM
rla2005's Avatar
rla2005
Please define "not getting anything on that front". No codes is a problem. If there are no errors flagged during the Key On Engine Off (KOEO) tests you would get the System Pass code 11 or 111. If there are no stored codes in Continuous Memory (CM) you would also get the System Pass Code 11 or 111.
If you did get "no codes" you either ran the tests wrong or you have a bad computer.
Given your stated symptom you probably have a bad TPS.
Old Jan 4, 2018 | 02:02 PM
rj1983's Avatar
rj1983
Sorry, get the pass code but nothing adverse.
Old Jan 4, 2018 | 04:03 PM
rla2005's Avatar
rla2005
Thanks for the clarification. As noted before the symptoms are pointing towards an issue with the TPS. Shutting off the truck, then restarting sets the minimum closed throttle TPS value back to default in the computer. As you drive the TPS signal is erratic so the computer is ratcheting up the minimum stored value which tends to increase the idle RPM.
On my old 1992 F350 I found the TPS connector had green corrosion inside of it. Static testing revealed no issues but when driving and heating up everything the resistance (therefore the feedback voltage) was changing. Cleaning that connector fixed my problem.
Others have found the TPS itself was getting "noisy" and throwing off the computer.
If you go this route I highly suggest a Ford/Motorcraft replacement. Aftermarket version are very susceptible to poor quality and early failures.
Old Jan 5, 2018 | 05:59 AM
rj1983's Avatar
rj1983
Too easy, thanks for the advice. Ill look into what you suggest tomorrow and report back.
RIKIL
Mar 9, 2013 01:43 PM
harryg753
Feb 13, 2012 12:59 PM
ATVBronco
Bronco II
23
May 5, 2006 01:34 PM
fordman 460
Bronco II
Jan 14, 2006 04:46 PM
Mass20
Dec 15, 2004 11:00 PM
