Help with engine codes
Old Mar 31, 2007 | 12:32 PM
ErnieX's Avatar
ErnieX
Hi guys,
Pulled codes on my '95 f-150 302 - trying to solve a rough, surging idle.
Codes
koeo - #111 - No problems, cm - #172 - Bank #1 lean
koer - #211 - Thermactor air system inoperable during test
#311 - Can't control idle during test - low RPM check
I replaced the tps and set voltage.
Replaced IAC - with new IAC diconnected, engine still idles level??? Bad part??
What would be the obvious things to look for based on the codes?
Thanks for any help.
GO GATORS!!!!!
Old Apr 1, 2007 | 08:37 AM
ErnieX's Avatar
ErnieX
^ bump bump
Old Apr 2, 2007 | 12:06 PM
ErnieX's Avatar
ErnieX
Everyone says check and post the codes and then we can help - WELL?????
Old Apr 2, 2007 | 04:48 PM
Bruce R Leech's Avatar
Bruce R Leech
you have me stumped on this one. some times you need to adjust the IAC might try that. also have you checked out the koer - #211 - Thermactor air system inoperable during test. what did you find there.
I am still thinking on this one so keep bumping it up. there are guys way smarter than I AND THEY ARE PROBABLY STILL THINKING ALSO
Old Apr 2, 2007 | 05:33 PM
andym's Avatar
andym
How do you adjust an IAC Bruce?
Old Apr 2, 2007 | 07:58 PM
Bruce R Leech
you are right I was stupid thanks for pointing it out. I was thinking of something else
Old Apr 3, 2007 | 06:50 AM
albung's Avatar
albung
my truck ran like that and was 02 sensor but i had checkengine lite
