electric choke for a '78 ford?
The choke/thermostat on my 351W is dead. It is the heat type with no electrical assist. I am looking to replace my dead choke/thermostat within electric one. How do I know which one I need based on these facts:
-Motorcraft 2150 carb
-351 winsor motor
-1978 Ford f250
-Carb tag reads something like this: "D7TECTA"
Does anyone know what choke I need for this carb? I'm not really sure which one i need for my truck and I don't really want to buy the wrong one.
-351 winsor motor
-1978 Ford f250
Dorman sells a repair kit for the choke hot-air stove to restore your original choke. You can also make a new hot-air stove out of brake line. What is the problem with your current hot-air choke; is the stove gone? Or is the stove there, but the choke cap is dead? Either problems are straightforward to solve (the latter being even easier).
If you find a factory Motorcraft choke with electric assist from another carburetor, it will not work without the original hot-air stove in place. The electric assist on those chokes does not kick in until the choke thermostat reaches a certain temperature - so they rely on the hot-air stove to heat them up first, and the electric assist only kicks in at the end. It's not a fully electric choke.
Holley and Edelbrock sell electric choke kits for their carburetors - however I do not know if they physically fit on a Motorcraft carburetor. They look similar, but I have never tried.
As far as I'm aware, my chokecap is the only dead part. My thermostat also doesn't work, but i don't know if that relates to this or not. I'd also rather just replace the heat powered choke with an electric for easier operation. I found a choke cap that says it should fit my carb, the only problem is that the number on the site doesn't match the number on the carb tag. Here's a link to the choke I'm considering: http://www.carburetor-parts.com/Moto...oke_p/1098.htm. Do you think this will fit/ work on my carb?
A bad thermostat will certainly delay the choke opening in an otherwise functioning setup, but it will open eventually because the heat is taken from an exhaust crossover and not a coolant passage. Regardless of what the choke is doing, if your thermostat is stuck open as you suspect, you must replace this immediately. The engine needs to run at 192 to 195 degrees F; prolonged operation at lower temperatures is bad for the engine. Also do not rely on the factory temperature gauge to tell you much.
What is the actual problem with the choke? What is it doing (or not doing) that it should not (or should) do? Is it stuck closed, but does not open? Is it stuck open and will not close? Does it start closed and open like it should, but open too quickly or too slowly? In each of these cases, you first have to make sure that the heat source is actually present, the choke is set properly, and the linkage is engaged.
With that said, what are the actual symptoms of the choke cap - not the truck in general? What is the choke doing now if you watch it during a cold start? Make sure to answer all these questions. Keep in mind with any carbureted engine, you must press the pedal once before a cold start (not pump) to free the fast idle linkage and load the choke.
The chokeplate doesnt open at all even after the engine has warmed up, and the choke cap itself stays ICE cold even after the engine has been (somewhat) running. The choke plate and the rest of the linkage works when I open it manually and hold it open with a screw driver.
Read this thread: https://www.ford-trucks.com/forums/8...-answered.html
'77 F100 Custom
12-06-2016 09:01 AM
77beater150
08-14-2014 11:41 PM
