CAT/Muffler Removal
Old Feb 9, 2012 | 04:42 PM
gmcbride's Avatar
gmcbride
CAT/Muffler Removal
I began the work to remove the CAT, for testing purposes only, and am a little stumped. Down pipe connection was easy, used some blaster on the CAT muffler connection, no good. It is a 4" slip connection that was spot welded with a clamp. Clamp came off, spot weld is gone, and no budge. I don't want to destroy the connection. I am doing this on my back. Anyone have any suggestions? Thank you, gm.
Old Feb 9, 2012 | 05:53 PM
zhilton's Avatar
zhilton
Mine wasn't spot weld/tact'd on the clamp but it was a real beach to get that "slip joint" to slip off there. Seems like I ended up using a dead-blow rubber mallet to convince the muffler to move. I made sure I was hitting round the rim of the muffler where the metal is the thickest.
Old Feb 9, 2012 | 08:48 PM
Mich6.0's Avatar
Mich6.0
Heat it up if you have torches, a butane torch might work but will take longer
jasonch
18
Dec 8, 2009 08:53 PM
breisr
17
Jul 24, 2009 02:19 PM
9.ford.5
Exhaust Systems
Jan 5, 2009 06:48 PM
semcderm
Modular V10 (6.8l)
Nov 19, 2008 12:43 PM
davidson915
Jan 28, 2008 03:56 PM
