Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
No reverse when warm
Old Feb 8, 2012 | 09:21 PM
duramaxthis's Avatar
duramaxthis
Girlfriend has a 2007 Escape with about 60,000 miles on it. Won't go into reverse when the tranny is warm (after it's been driven), works fine when it's cold. Scanner says it recognizes it's in reverse when it won't move. Absolutely no problems going forward. Any ideas other than the whole transmission is junk.
Old Feb 9, 2012 | 07:51 AM
tomw's Avatar
tomw
Check the fluid level when it is up to temperature and won't provide reverse. The internal and external shift linkages could be damaged or out of adjustment. The internal shift linkage could be disconnected. Reverse clutch assembly and low/reverse clutch assembly could be damaged leading to low line pressure.
If this occurred over time, it points to slow pressure loss or friction/steel damage in the clutches. If this occurred quickly, it is not as likely to be something as significant as the clutches, and is more likely control valves and linkage. There is a large list of possible suspects in the shop manual, and I can't type them all.
Needless to say, I'd call a transmission specialist who may know the cause that applies in a majority of cases, and be able to diagnose the problem almost w/o looking at the vehicle.
tom
f350rebel7788
24
Nov 19, 2021 09:43 PM
Wild-Bill
Dec 12, 2013 05:56 AM
elotus
Aug 25, 2011 08:23 PM
Country705
Feb 11, 2007 08:45 AM
cfltitans
Jan 23, 2006 06:32 AM
