I have lost reverse in my van. All forward gears seem to work fine, but when you shift into reverse I get nothing. Also the vehicle appears to be in 1st gear in neutral.
I have checked linkage. It appears to be working normally. I have disconnected it & shifted the tranny manually from under the vehicle & it still has no reverse and a forward gear in neutral.
When it is on the jack stands & I shift into reverse the tranny appears to engage and will roll the tires forward about 3-4 revolutions and then stops.
I have checked modulator valve & fluid. the modulator valve appear to be fine. The fluid level looks ok, the color is good & it doesn't smell burned.
Any ideals or insite would be greatly appreciated.
